Valve seals unseated
Any ideas or just re-seat and check periodically ?
After talking with BTR and my local machine shop it may be the Kent Moore tool causing the issue. The bottom of the failed seals has a small lip that may be due to the tool being designed for the stock valve seals. When I tap it down it may be seating it too deep and causing the lip that gets caught on the inner spring. New seals on the way and hopefully that fixes the problem.
I purchased that Kent Moore tool in preparation of installing BTR springs...
Is that tool the J-42078 GEN III?
Did Brian himself state the Kent Moore tool was "possibly" the problem?
Looks like most people use a 12 point 12mm deep socket and gently hammer them on but I figured the Kent Moore tool would be safer.
Has anyone else out there used the Kent Moore tool and had issues with aftermarket seals?
Original 243 heads with 38K on the motor. 7.4 pushrods, comp trunion upgrade.
Maybe try the Blue Viton seals?
weird.
Also, do you have good clearance between the inner spring and seal when your first sliding the springs on?
I checked the other seals and they match ID and OD. But they were only on for a few days.
I assume you are running the BTR springs also ?
