My custom grind cam specs.
3400 stall will work depending on ICL. Generally I would like seeing that cam on a 108 ICL with the larger runner head. On the stock 241 heads that I had I opted to move the IVC point out a little further to grasp the top end power I was after and it worked well and had a nice single arch torque curve! I later installed TEA St2 799 heads that had been milled to 62cc and i def had to flycut the pistons at that point. But the combo didn't really work well with the cylinder heads. The cam really needed to be advanced a couple degrees to make use of the larger heads. This is why it's important to match the combo of parts and not just random parts from various vendors.
