any input on 226/232
Old Feb 12, 2014 | 03:51 PM
kodyowenby10's Avatar
Default any input on 226/232
looking at a http://www.summitracing.com/parts/hr...make/chevrolet for my 55 chevy with lm7 all stock truck intake headers 3.73 gear 4 speed muncie weighs around 3500ish. It will be a weekend cruiser with a/c might run the drag strip every now and then.
Old Feb 12, 2014 | 06:54 PM
99Bluz28's Avatar
Should be a nice overall cam by the look of the specs, but you haven't told us enough to infer if you'll like it, or not. FYI, depending on how aggressive you're willing to go on cam lobe ramp rates, the power band you're looking for, and how smooth or rough you want you idle, you've go at least 4 additional options from Howards Cams that you might like better.
I'd probably also look at the Howards # 197715-10.
http://www.summitracing.com/parts/hr...5-10/overview/
Old Feb 12, 2014 | 06:56 PM
garygnu's Avatar
try competitions products ,they sell howards cam ,mite cheaper then summit .
Old Feb 13, 2014 | 11:13 AM
I want a rough idle power range around 18/2000-6500ish dont plan on any other mods for a while will mainly just be a cruiser
Old Feb 13, 2014 | 12:39 PM
99Bluz28's Avatar
I'd go with the cam I recommended then. It has less max lift but has more aggressive lobe ramp rates, which will allow more flow within its lift range by opening valves quicker. This cam will also have it's power band slightly lower in the rpm range, and with 11* overlap it will clearly have a more aggressive idle, while also having a high DCR for more power and TQ.
BTW, Tick Performance also offers a very similar cam, which would also be another good option.
http://www.tickperformance.com/tick-...1-ls6-engines/
Old Feb 16, 2014 | 03:43 PM
which would be better the howards asa cam you suggested or go with the gm asa cam? Also what springs would be best ls6 or go ahead with ls9 I would rather reuse my stock hardware and just swap springs. Also with lower lift are push rods still recomended?
Old Feb 16, 2014 | 05:16 PM
99Bluz28's Avatar
The Howards #197715-10 and the GM ASA cam will have the same overlap(@.05") and sound the same, but the Howards will make more Hp/Tq compared to the GM ASA, and I believe it has a has a lower IVC than the GM ASA (39* vs 41*). The only benefit of the GM cam is the milder lobes which would have longer valve train life, so and you could use less expensive LS6 springs. With the Howards I'd run a set of PAC1211X beehive springs.
Old Feb 16, 2014 | 06:25 PM
what do you thank about push rods use stock or get some hardened one?
Old Feb 16, 2014 | 07:08 PM
redtan's Avatar
You definitely have to use hardened ones for anything besides a stock cam.
