budget build. L92 iron or ?
I was thinking, the crank and rods from the L33 (since theyre floating) with the ARP bolts. Then either getting flat tops, or boring to 4.065 and run LS3/L92 slugs. It's going in my DD. I'd like maybe 450ish wheel. It's in a 2wd Yukon, with a lil weight reduction, so maybe 5200.
I'll build it one piece at a time. My other question, is cathedral or square ports? How would 243s with some work done be on a 6.2? I know alot of people say the Square ports, you lose bottom end. I'll of course stall it and a cam. I have 3.73s. Just looking for opinions from the gurus and getting knowledge on what will work. I'd really love to maybe hit them 12s.
As for Rectangle vs Cathedral ports, it's been beaten to death. Everyone has their own opinion based on what their experiences are. My experience tells me that the cathedral ports make better power in the range that a street car usually spends its time. However, as the displacement and/or RPM increases, it's harder to feed the engine with the cathedral port heads, so the rectangle port heads look better and better.
