54-448-11 comp cam
COMP Cams#249-54-448-11
XFI XE-R Hydraulic Roller Camshaft
GM Gen III/LS1/LS2/LS6 1997-PRESENT (Three-Bolt)
Lift: .605''/.609''
Duration: 287°/289°
Lobe Separation Angle: 112°
RPM Range: 2800-7200
Will this fit in a 99 ls1 with stock bottom end and 243 heads with out clearence issues. Also how much power will the motor make on an estimate. 243 heads cam ls6 intake. Thanks guys!
Lift: .605''/.609''
Duration: 287°/289°
