LS1 Milled 243s MS3 PTV Issues
Old Feb 17, 2014 | 09:25 AM
PREDATOR-Z's Avatar
You need to flycut for that type combo. MS3 cannot accept any mill on heads with stock bottom.
Old Feb 17, 2014 | 09:29 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Definitely need to flycut that. I would not expect a set of LS6 heads milled .035 with a .041 gasket and a stock piston to clear. If it does, it does not have enough to remain safe.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Feb 17, 2014 | 11:46 AM
LSX_240's Avatar
Thats why I was checking ,to see how much exactly to cut. Should i just cut X amount or measure and do exactly what i need?
Old Feb 17, 2014 | 01:10 PM
.boB's Avatar
Originally Posted by LSX_240
Stock bottom end Ls1, 243 Milled .035, Cometic MLS .041, MS3 at 113. Checked PTV several times and the clay looks like the valves are CLOSED when it hits. Had a friend come over and double double check with the same results. Is this normal or are we doing something wrong? Any help is much appreciated.
That is a physical impossibility. It just can't happen. The pistons are flat, and the chamber is a bowl. The chamber is not round, and smaller than the diameter of the piston. There's no way the piston can extend into the chamber enough to hit a closed valve.
To properly clay the pistons, you need to use checking springs, or a modified solid lifter. Either one will get you what you want. But I find checking springs to be cheaper and easier. You can buy the springs you need at pretty much any hardware store. But they look something like this:
I have 8 springs, so I can do one head at a time. Overkill, I know. But it makes me feel better to check each one.
Put a 1/4" layer of clay on the piston, and bolt the head on using the old gasket. Doesn't need to be torqued all the way, just kinda tight. Turn the engine over a few times.
After removing the head, use a razor blade to carefully slice the clay. I cut about 1/4" slices. Measure at the narrowest part.
Old Feb 17, 2014 | 03:06 PM
LSX_240's Avatar
Sry for the confusion. Again, I say the piston is not hitting the closed valves. I have enough clay in the whole THE CLAY HITS THE CLOSED VALVES and that is the impression it leaves on the clay.
Old Feb 17, 2014 | 04:34 PM
Something is missing then. Take a picture of exactly what you are doing and I'm betting it can be figured out.
__________________
Old Feb 17, 2014 | 05:04 PM
RezinTexas's Avatar
this writeup may help you.
http://www.scribd.com/doc/137049285/...RAFT-20-Apr-13
Old Feb 17, 2014 | 05:43 PM
sepsis's Avatar
Well, are you turning it over so the valves open too?
If you put enough clay in there, of course it's going to touch the head, but that won't tell you anything until the valve opens and leave its impression.
Old Feb 17, 2014 | 07:08 PM
PREDATOR-Z's Avatar
Ptv clearance is usually measured 10 degrees Btdc to 10 degrees Atdc. That is where contact usually occurs.
Old Feb 17, 2014 | 07:28 PM
.boB's Avatar
Well, that's never going to work. Only put about 1/4-1/2" of clay on the piston top and try it again.
