Rocker Arm Removal
Then I used my cheap electric impact wrench and spun them out, just as easy as any bolt should be. All 16 of them. I wouldn't have thought it would be such a simple answer - but I like trying the cheap and easy things first.
Thanx, guys. Appreciate your help.
Believe it or not, these are the correct answers! I stopped at Lowes and got a new 6 point socket to replace my 12 point. And then I whacked 'em with a center punch a couple of times.
Glad you figured it out
( BTW: also do this on things like on idler pulley torx bolt, and on 4L60E bellhousing-to-case torx+ bolts )
And then, before installing rocker bolts, clean threads out with a chaser.
But, on inspection, all of my smaller sized sockets are 6 point. I didn't use metrics that much, so for this project I had to buy a couple of sets of new sockets. Most of them are 12 points. If it happens again, I'll know what the problem is.
Just goes to show that no matter how old you are, or how much experience you have, you can always learn something new.
Wish I could take credit for figuring it out, but it wasn't me. Vettenuts suggested it.
I actually like the stock bolts better than the Allen head bolts that came with my YT rockers. Has a better shank. Ditto for the stock rockers with comp reunion upgrade. But in that situation, the stockers are too short.
So, you will get to buy another new metric tool! 3/8 Allen socket.
Since getting into the LS stuff, I now have more metric tools than std.
Ron
I'v applied heat to the bolt head and the rocker pedestal.
My hand impact tool will usually break anything free. Jut put a little tension on it and whack it with a big hammer. That usually breaks things free in a coupple of hits.
darn tootin!
