What would my CR be with this combo?
63cc - 10.20:1
62cc - 10.33:1
61cc - 10.46:1
60cc - 10.60:1
59cc - 10.74:1
58cc - 10.88:1
Just remember that these are for customer supplied heads. We no longer sell these heads outright as we cannot get any new 5.3 castings at the pricing that we once could. You have LS6 heads on your set up right now. The compression would be the same if you sent those in to be worked over given the same combustion chamber size as mentioned. The pricing is also the same as sending in 5.3 heads.
Thank you,
Lonnie
I bought the heads as a heads and cam, and heavy duty timing chain combo a few years ago. Is there anyway we could go back and look at which style I went with?
I ordered an MS3 cam, and wanted to be sure that I had piston to valve clearance (which I did).
Lonnie
I'd like to get my CR down to around 10:1 or so. Can this be done with running a larger head gasket?
Lonnie
That being said, I could probably sell my heads for more than it would cost me to have the stock 5.3 heads worked over I suppose.
