Trick Flow Timing Chain Damper Adapter
Old Feb 20, 2014 | 10:34 AM
BlueBird346's Avatar
Default Trick Flow Timing Chain Damper Adapter
Does anyone know if these can be used with the newer style cam retainer plate, that has the counter sunk bolts?
With a Katech C5R chain, should I even bother with a damper?
I may do some road course type stuff in the future, so I'd like to not have to worry about it.
Old Feb 20, 2014 | 11:06 AM
ls1 1990 VN's Avatar
Can't see why not.
I run the Cloyes Hex a just gears & C5R chain, also added the Trickflow bracket so I could use the LS2 damper. Insurance in fitting is better than not fitting & always wondering.
Old Feb 20, 2014 | 11:47 AM
ckpitt55's Avatar
no reason to run the newer style retainer plate when the older one is available and cheap.
Old Feb 20, 2014 | 12:30 PM
Where can I get the old style from? Already bought the new one, did a quick search and didn't see the old style tho.
Old Feb 20, 2014 | 12:59 PM
RonSSNova's Avatar
What engine are you working with?
Is the block drilled for the damper?
I believe the early blocks weren't drilled, so if that's the case, use the trick flow setup.
If an early block that's drilled, I believe the damper is discontinued, so you will still need the TF part.
If its the later block, with the holes drilled, I believe Brian Tooley has the dampers.
My L33 was drilled, so I bought a damper. Running the std cloyes hex adj setup
Ron
Old Feb 20, 2014 | 02:31 PM
Yea it's a '99 LS1. My main problem is will it fit the newer cam retainer plate, and if not, where can I buy an old style.
Burken01's Avatar
It doesn't matter which cam plate you use, the TFS damper kit comes with button head bolts that you use when the damper plate goes over the cam plate
Just buy whatever cam plate that you can get the cheapest
Old Feb 21, 2014 | 05:59 AM
vettenuts's Avatar
Anyone got photos of this install. Have always been curious about it. As for the cam plate, I think guys were buying them somewhere other than GM. Can't remember where but it was posted in a thread about a year ago.
OP, if you plan road racing my opinion is the damper is a must. There is an issue with chain wrap when decelerating that can break the chain. The damper prevents this.
Old Feb 21, 2014 | 09:51 AM
Burken01's Avatar
Here I found one
Attached Thumbnails Trick Flow Timing Chain Damper Adapter-image-3665502982.jpg
Old Feb 21, 2014 | 10:07 AM
ckpitt55's Avatar
Rock Auto has them, VICTOR REINZ Part # B31822.
Here are a few pics from my install.
Old Feb 21, 2014 | 11:41 AM
Coonass350's Avatar
Been wondering what it looked like setup. Thanks for posting the pics
Old Feb 21, 2014 | 12:07 PM
Thanks guys. Guess I'm gonna pick up a few of these parts soon.
Old Feb 21, 2014 | 12:27 PM
.boB's Avatar
On a similar note.
I recently read that you should not re-use the cam retainer plate. You should always replace it. Is that true?
Old Feb 21, 2014 | 12:32 PM
Burken01's Avatar
Originally Posted by .boB
On a similar note.
If your tearing down a high mileage engine then yes replace it because the gasket will be completely flat..
If its new and you only have 20k-30k miles on it then you might be able to reuse if the gasket is still raised and spongy. Use your own judgement though!
Keep in mind they are only $20 bucks, so if its questionable then replace it.
Old Feb 21, 2014 | 12:41 PM
vettenuts's Avatar
Great photos guys, thanks.
Old Feb 21, 2014 | 12:45 PM
mchicia1's Avatar
Very cool, I didn't know anyone had a product like this.
Old Feb 21, 2014 | 02:04 PM
studderin's Avatar
yes, seen this on high mile cars. And replace them. Same on cars that have been over heated. I dont know the history of every car but some that have the covers and gasket bonded, like you have to rip the seal off probably were.
new and fresh under 2 year 20K cam plates you can see and feel the seal soft and raised above the plate surface, and most plates with miles are flat
Old Feb 21, 2014 | 05:36 PM
Yep mine has 150k on it. That's why I bought the new one.
Old Feb 21, 2014 | 06:49 PM
Beatdown Z's Avatar
X2, thats pretty neat.
Old Feb 22, 2014 | 10:45 AM
ckpitt55's Avatar
I'm running the Cloyes hexajust timing set on my setup - with everything installed there is very little play in the chain. It was actually kind of difficult to install, but that's a good thing imo. Nice, tight fit.
Upgrading your chain and installing this damper are great changes to make while youre in there, especially if road racing. This would compliment a good harmonic (crank) damper nicely.
