Will this cam make power with a stock ls1?
Old Feb 22, 2014 | 09:07 AM
jimmy92rs's Avatar
Default Will this cam make power with a stock ls1?
So my friend gave me this new camshaft. It's a comp cam 54-464-11. The specs are .251/.259 duration .624/.624 lift and 115 lobe sep. He was originally going to install it in his 07 z06 but went a different route. Do you think this will make decent power in a 01 ls1? Opinions please and thanks in advance.
Old Feb 22, 2014 | 09:27 AM
td1168's Avatar
That's too too much cam for a stock ls1! If you look at Comps recommendations for the cam they tell you its for larger displacement ls engines with high compression and for race applications.
http://www.compcams.com/Company/CC/c...csid=1408&sb=0
Old Feb 22, 2014 | 09:40 AM
jimmy92rs's Avatar
Yeah I know it's meant for a larger cubed LSX but If i ran I wonder what it would make decent power.
Old Feb 22, 2014 | 10:30 AM
td1168's Avatar
That cam will lower your dynamic compression too much. I doubt its going to make decent power. That's just my opinion.
Old Feb 22, 2014 | 01:38 PM
jimmy92rs's Avatar
Do you think that because the duration is high?
Old Feb 22, 2014 | 02:23 PM
KCS's Avatar
KCS
Moderator
It's gonna run like ***.
Old Feb 22, 2014 | 02:31 PM
JakeFusion's Avatar
Super Hulk Smash
Couple of things:
1) It will have 25 degrees of overlap. That can be tuned in a 346, but it will run poorly. The old T-Rex had 25 degrees of overlap. It was a 242/248 110. It could mush up your brakes and you needed like 4.30s and a 4000+ stall just to run that. And that was with the valve events designed for a 346. The 251/259 115 push the valve events way out of the optimal range for a 346. I doubt you'd have much luck driving that below 2500 RPM.
2) The cam is so large, the IVC is so late, you will not make torque. You'd need at least 12.5:1 CR on the motor to build decent torque. And your manifold is not optimized to make peak power at 7000+ RPM. The manifold design peaks around 6300-6400 and the cam has to be attenuated to that to optimize both torque and HP curves. This is optimized for 7500+ in your motor.
3) I doubt it'd actually fit the shortblock without flycutting. Depending on where the ICL of the intake lobe is, you'll be kissing valves with the piston unless you flycut.
Old Feb 22, 2014 | 04:08 PM
jimmy92rs's Avatar
Thanks for the info. I'm going to see since the cam is brand new in the box if comp will let swap it with a cam more suitable for me engines needs. What's a good comp cam for only a loudmouth exhaust and cold air intake upgrades and a ls6 intake on my ls1?
Old Feb 22, 2014 | 04:18 PM
jimmy92rs's Avatar
Double post
Old Feb 22, 2014 | 04:39 PM
Blackpanther99's Avatar
Too big...
Old Feb 26, 2014 | 01:30 AM
fordkilla2000's Avatar
Definitely too much cam for stock ls1. Just get a TSP 228R 112 cam and port heads
