whos heads are these
Old Feb 22, 2014 | 02:50 PM
BKsNHRA's Avatar
Default whos heads are these
Ive been searching around trying to find info on these heads. Not that its a big deal but more curious as to where they came from. Only distinctive marks on the heads are a letter A in one port on both heads. All the valves where recently replace and the springs. They have welds around all the spring pockets by the springs. Bronze guides. 2.02 1.60 valve and are 243 heads .I was told they where purchased from thunder racing but I really have no idea. Here are some pics
Attached Thumbnails whos heads are these-159.jpg   whos heads are these-164.jpg   whos heads are these-166.jpg   whos heads are these-167.jpg   whos heads are these-165.jpg
Old Feb 22, 2014 | 02:59 PM
BKsNHRA's Avatar
heres another
Old Feb 22, 2014 | 04:29 PM
BKsNHRA's Avatar
From lots of research I have found a little that says these may be some JPR Heads and also LG Heads. Can anyone comfirm this and maybe provide a bit more info on them.
https://ls1tech.com/forums/generatio...ls6-heads.html
^^ This is all I have found to go on
Old Feb 23, 2014 | 06:47 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
There was a guy named Craig who used to hand port heads for Thunder and the local area back around 2000-2002ish. Geoff was telling me stories about him last time I was there.
They never were as "pretty" as a CNC'd head, but good lord they made power; awesome power back then. They were gettting consistent 450's 460's with just medium cams, stock TB's and an LS6 intake.
I'd shoot those pics to Geoff and see if he knows. I'm sure he'd recognize them if they were indeed Craig's work.
Old Feb 23, 2014 | 07:47 AM
BKsNHRA's Avatar
Sounds good. I gotta call him tomarrow anyway so ill run it by him
Old Feb 23, 2014 | 08:07 AM
v8pwr's Avatar
They never were as "pretty" as a CNC'd head, but good lord they made power, for BACK THEN. They were gettting consistent 450's 460's with just medium cams, stock TB's and an LS6 intake.
You're thinking of Craig Gallant GTP heads. If these are GTP heads you have a very good set of heads that will make great power. Call Craig and he can help identify his work.
Old Feb 23, 2014 | 09:28 AM
BKsNHRA's Avatar
Heres a few more. The valves and springs were recently replaced due to some was bent and had to have a chamber welded up and fix. But now you cant tell the difference between the others. Got the heads cheap but had to put a good bit in them to fix them.
Attached Thumbnails whos heads are these-img_3682.jpg   whos heads are these-img_3686.jpg   whos heads are these-img_3684.jpg
Old Feb 23, 2014 | 09:30 AM
BKsNHRA's Avatar
and the last 2
Attached Thumbnails whos heads are these-img_3678.jpg   whos heads are these-img_3685.jpg
Old Feb 24, 2014 | 02:22 PM
BKsNHRA's Avatar
Geoff says they don't look like gtp heads. The search continues!
