Short duration, Tight LSA Cams
Thanks for the response. Developing torque across the entire bandwith is more important than peak horsepower numbers where the engine will rarely spend any time for my application. I am very interested in the ASP-Kicker cam. Let me know what valve springs you recommend for this cam (I see some springs rated for 0.650" lift on your website). Also, have you experimented with any reverse split cam patterns?
Thanks,
Glen
Is it due to the smaller sized motors, the extra 2000lbs of weight some trucks carry over the f-body's, or is it the relatively lazier lobes of the 216/220?
BTW, my DTD 2000 setup shows equal to stock torque @ 2000 for the 212-216 range cams and then less @ larger durations. I'm not saying that this stuff is accurate. It is just useful when comparing cam characteristics.
To each his own I guess. Everybody has a different idea of what's streetable.
Keep reading around if you do not believe me. It is a general agreement that a TC swap is more beneficial than a cam swap (ET times) therefore performance and should be done first.
The decision I made was that I DON'T want to go faster than 12.0. I think I can get into the low 12s with a mild cam and headers. Both the mild cam and headers should improve driveability. Maintaining driveability is now one of the top goals.
If in my normal driving the TC locked up 25% of the time, I would still be on the fence on whether or not to go with a hi-stall TC. At 50% lockup I would be convinced that the TC is the way to go. At 75%, I would be a fool not to get a TC. I almost never lockup my TC. In fact the only time it gets locked up is when I head out to the track on the other side of the island.
So, that is why I am going to stick with the stock TC. But I do appreciate your words of wisdom as it does apply to most peoples desires and situations out there.
Lockup in the truck takes place at 35mph. I have 4.10 gears, and 31" tires I believe. I regularily see 1,100rpm locked up on a nice flat road at about 35-36mph... If I choose to only lockup above 1,500rpm - I think I'll be looking at about 50, maybe 55 mph. Some of us may not want to sacrifice that (extreme?) lowend grunt.
I have a friend on these boards who has an A4 with stock 3.23 gearing and stock converter, that's putting down 370rwhp (SAE corrected), with every bolt on known to man, including 1.8 ratio rockers... his best on QTP drag tires is a 12.8... and this guy can flat out drive that car, so I'd be impressed if anyone could go faster in it. If he adds a mild cam like the type you're talking about, he can probably get a 12.5. But without at least a mild converter he probably wouldn't get the low 12s.
I just don't see a 12.0-12.3 in your future without at least a mild stall converter, especially if you're sticking with a mild cam setup.
I think the stock cam with its lack of advance, relatively low lift and wide LSA is a real dog off the line unless you change gears or converter. Just my $.02.
My engine doesn't really buck at all over 1000 RPM in first or second gears once it's warmed up. That's really why I kept duration below 220. FYI I have my idle set at 800 RPM.
When does it start to pull "healthy?" That's pretty subjective. I cruise at 70 MPH and 1500 RPM in 6th gear on the highway with enough grunt to change lanes and casually pass. On the other hand if I am in a race from a roll I never let engine speed drop below 3000 RPM in any gear above 1st. That's where the real surge comes on. The overlap on a 112 LSA gives you a definite hump in the torque curve. You can really feel when you're on it.
In a heavier vehicle like a truck you may have to go a bit lower in effective duration to have the same results, even if you have a 6.0L. With an auto tranny it might also be preferable to go with a 114 LSA to smooth out the idle a bit if you plan on keeping the stock idle speed.
Hope this helps - Jeff L.
For me, even a mild stall could really hurt my gas mileage and take away from the snappy throttle response. So, if I were to go with a TC, I'd go relatively big and try to reap the best ET from the $$ & effort.
The Colonel once said that the stock TC stall is even too low for the stock cam. That got me thinking. Instead of trying to increase the stall speed of the TC, what about increasing the low-end powerband to help the stock TC out. It is very evident that I'll run into more limitations as far as trying to increase the low-end vs. just increasing stall speed. But, there isn't much of a driveability trade-off by trying to do so.
Anyway, I appreciate your opinion.
Yes the bottom end will take a few more rpms but that is done at the expense of locking the bottom one of these days.
Comp 216/220 is a good cam also (peak hp at 6300rpm)
