06 5.3 cam question
Old Feb 25, 2014 | 03:41 PM
+badss+'s Avatar
Default 06 5.3 cam question
Hey my 06 flex fuel 5.3 cam is toast can i put a z06 cam and springs in without a tune. Everything is stock just want to know if it's worth doing I also tow my race car with the truck.
Old Feb 25, 2014 | 04:18 PM
joshua022's Avatar
How do you know the cam is toast?
And even if it is I wouldn't waste my time/effort on swapping in a z06 cam.
Old Feb 25, 2014 | 05:53 PM
+badss+'s Avatar
Um because of the lobes being scorched and the lifter have marks on them
Just was wondering if putting a cam that would work with everything without being a headache. Just figured I can do the cam it's $40 bucks more then the stocker.
Old Feb 25, 2014 | 07:05 PM
joshua022's Avatar
Do you have really high mileage or a reason that would cause that kind of excessive wear on the cam and lifters?
Bad oil pressure?
Old Feb 25, 2014 | 09:59 PM
+badss+'s Avatar
I got the truck used with 86k miles. just a couple weeks ago I noticed oil lvl dropped from 40-42 hot down to 37ish just started making the noise last week and we pulled the engine,after checking rockers and stuff pulled pan had some metal in it I was thinking a spun rod until we pulled heads and saw the lifters bearings are fine everything looks okay except cam and lifters.
So who knows how truck was with original owner.
Old Feb 25, 2014 | 10:05 PM
ronsws6's Avatar
I would first be really concerned with what "toasted" your stock cam.
Others can chime in, but I personally have never seen one that bad without a major oiling problem.
Old Feb 25, 2014 | 10:12 PM
pdsq98gt's Avatar
It's not really that uncommon. I personally think it starts out with either the lifter roller sticking or the lifter twisting slightly in the retainer. Of course it could be the heat treating of the cam.
Old Feb 26, 2014 | 03:56 PM
+badss+'s Avatar
From searching lifter issue is actually quite common.
So I'm buying some ls7 lifters
Old Feb 26, 2014 | 03:59 PM
+badss+'s Avatar
I was just thinking how can putting a zo6 cam in be worse then stock I do know a guy with a
06 pickup with a 6.0 did a swap z06 cam lifters and springs and he loves it.
So I was just seeing what others thoughts were on doing it since engine is out and right there.
Old Feb 26, 2014 | 04:16 PM
PREDATOR-Z's Avatar
check your spring pressures as well
