crank bolt
Old Feb 26, 2014 | 03:56 PM
BOTTLE ROCKET's Avatar
Default crank bolt
Has anyone used one of the "massive speed" crank bolts?
They are supposed to have a 197,000 tensile strength and is a 12.9 grade bolt.
I am building a forged engine with boost.
Stock - $4
Massive speed - $26
ARP - $36
Old Feb 27, 2014 | 02:53 AM
Quick Ranger's Avatar
For not that big of a price difference, i'd get the ARP bolt. You know for a fact that bolt is reuseable. Look around, i've seen them for around $30.
Old Feb 27, 2014 | 03:52 AM
LS1rob00's Avatar
ARP and be done with it.
"Buy once, cry once"
Old Feb 27, 2014 | 07:10 AM
slt200mph's Avatar
ARP = no brainer...
Old Feb 27, 2014 | 08:54 AM
Exidous's Avatar
Going with the Alper China stuff for head studs when the price difference is north of $200 makes some sense if you aren't building a +1000whp monster. But for a $10 difference on a part that is spinning around its entire life and could even be left up to spinning a supercharger the ARP is a no brainer.
Old Feb 28, 2014 | 01:34 PM
iliveonnitro's Avatar
I'm going against the grain on this one. If it's a Grade 12.9 bolt, it's fine to use. This isn't a case where "name brand" is necessarily better than generic.
The only reason to get the ARP over the Massive Speed one is because of the field data on reliability. Honestly, though, I'm not sure it matters in this case.
Old Feb 28, 2014 | 02:18 PM
slt200mph's Avatar
Wake the phuch up people BUY AMERICAN!! Phuch China and all the rest of the world. Hoooray for the USA!.. Nuff said.
Old Feb 28, 2014 | 06:14 PM
Paul Bell's Avatar
That's MISTER MODERATOR
The Massive Speed bolt looks to have "12.9" on the head HOWEVER, it's a standard 12 point head flange. The ARP bolt has a considerably larger flange load area as well huge 12 point head that you can hang a big wrench on.
About the "made in China" issue, it's commonly known that Chinese made products often DO NOT attain the specifications they claim. I would not be surprised if this bolt was a 9.8 or 10.9 grade. I would also question the thread quality. Chinese production rarely has good Q&A and test to fail procedures.
Stay safe-stay with the ARP.
Old Feb 28, 2014 | 08:16 PM
ChevyOwner's Avatar
I don't see why a grade 10.9 bolt won't work I have the old GM bolt out of one here, it has 10.9 on the head.
Or am I missing something?
Old Feb 28, 2014 | 08:24 PM
Paul Bell's Avatar
The GM bolt is TTY. A non TTY bolt needs to be torqued to 235 ft-lbs WITH lube.
Old Mar 2, 2014 | 12:05 AM
cbenn47's Avatar
I just went ahead and bought ARP for mine, the rest of my bolting is ARP so I just kept it the same.
Old Mar 2, 2014 | 09:27 AM
ChevyOwner's Avatar
I guess a better way to put it is...
I don't understand why a 10.9 non TTY bolt won't work.
I know that the gm bolt is TTY, and the ARP is not.
Why won't a 10.9 bolt that is not torque to yield work?
Old Mar 2, 2014 | 09:55 AM
Paul Bell's Avatar
235 Is a pretty steep torque load for this bolt. The GM bolt is designed to stretch just right. The ARP bolt is designed to hold at 235 ft-pounds. A standard class 10.9 bolt may stretch more than required or f fail completely.
Use the correct GM bolt installed to the correct angle OR the ARP bolt torqued to 235 ft-pounds.
This is not an area you'd like to discover a fastener failure.
Old Mar 2, 2014 | 09:56 AM
01ssreda4's Avatar
Its your crank, go ahead
Old Mar 2, 2014 | 09:17 PM
ChevyOwner's Avatar
I asked because I am too curious. I have a new GM bolt to install my new balancer, but if I needed to get one I'd get the ARP.
Old Mar 2, 2014 | 09:24 PM
Modchevelle's Avatar
I was going exactly the same route but chose ARP a trusted name. I know the Massive is made in USA we think but is it good?
Old Mar 2, 2014 | 10:46 PM
Paul Bell's Avatar
Ya can't go wrong with the GM bolt. Just:
-Use a balancer installer, not the bolt to get the balancer on the crank;
-Properly install the bolt, torque to 37 ft-pounds then turn another 140 degrees.
Old May 13, 2014 | 11:15 AM
K STYLEZ's Avatar
Sorry to dig up the dead... I used the Massive on mine. Used their XL-LS longer bolt since the threads were all messed up on mine. They are made in the USA and pretty darn stout.
https://ls1tech.com/forums/generatio...l#post18095969
Old May 13, 2014 | 12:24 PM
JakeFusion's Avatar
Super Hulk Smash
It shouldn't be $36 for the ARP. I think I paid $25 shipped for mine.
And it calls for 250ft/lbs IIRC.
