THE answer to your ls7 lifter woes.
Old Mar 3, 2014 | 03:45 AM
Quick Ranger's Avatar
Thanks for the input, i'd rather run the tie bar lifters myself. Just prefer to do without the plastic trays.
Old Mar 3, 2014 | 12:18 PM
COSPEED2's Avatar
LS1Tech Sponsor
The lunati "streets" are made by morel and are a very good quality for an inexpensive tie bar set.
Old Mar 3, 2014 | 02:03 PM
COSPEED2's Avatar
LS1Tech Sponsor
I dont like the plastic trays much myself but some budgets are not cut out for them.
Old Mar 5, 2014 | 12:37 PM
mchicia1's Avatar
I contacted Lunati. I was told they are comparable to the street lifters, but no link bar.
Old Mar 5, 2014 | 12:38 PM
COSPEED's Avatar
That is correct, they are great lifters, good up to 6K. For the price, it's great.
Old Mar 5, 2014 | 12:40 PM
mchicia1's Avatar
Good, these will be perfect for the mild build I am doing then.
Old Mar 5, 2014 | 03:05 PM
LS1-450's Avatar
This thread caused a change in plans regarding the installation of our 231/237, 598/595, 112 cam. Were not able to confirm what lobes it has. Companies did try to help identify it, but, could not, due to its' age (over the phone). Can anyone identify the typical lobe ramp for this cam when it was released...more than 5 yrs ago? To stay on topic, it is the concern of LS7 lifter failure due to XER or other overly aggressive cam lobes that have kept us from using the cam.
Old Mar 5, 2014 | 03:18 PM
COSPEED2's Avatar
LS1Tech Sponsor
If you get a set of lifters I can possibly ID the cam!
Old Mar 5, 2014 | 03:30 PM
COSPEED2's Avatar
LS1Tech Sponsor
13045 intake lobe which is pretty dang aggressive. It is a newer lobe. Prob released around 2009-2010. The exhaust, either your duration is off by a degree or the lift is.
Old Mar 5, 2014 | 04:50 PM
LS1-450's Avatar
Thank-you
Old Mar 5, 2014 | 05:08 PM
badassracing's Avatar
The 13045 lobe is an HUC lobe. The HUC description says "very smooth design intended for high rpm use with heavy valves". I don't know if I'd call that aggressive?
Old Mar 5, 2014 | 05:15 PM
  #32
COSPEED2's Avatar
LS1Tech Sponsor
It is designed off the extreme marine lobe and is a bit softer, but it is an aggressive lobe. Not like the LSK or the like, but still more than a std lobe.
Old Mar 6, 2014 | 01:54 AM
  #33
ls1 1990 VN's Avatar
Hi, hey you seem extremely knowledgeable, I use LS7 Caddy race lifters & have wondered why in many other LS7 lifter threads why they aren't using these as an alternative to the normal LS7 lifters.
Old Mar 6, 2014 | 11:24 AM
  #34
COSPEED2's Avatar
LS1Tech Sponsor
They have a huge stigma about quite a few failures and not performing as intended quite a while back.
Kinda like Scorpion rockers.
They are still rather pricey and I would rather sell the Lunati's or Comps over them.
Old Mar 11, 2014 | 10:38 PM
  #35
COSPEED's Avatar
Here they are, just under a different part number. We've got these at an introductory price and then BAM, it goes up.
http://www.coloradospeed.com/delphi-...s-p-32274.html
Here are the Morel drop ins at an introductory price and then BAM, it goes up.
http://www.coloradospeed.com/morel-h...3-p-32269.html
Old Mar 18, 2014 | 04:59 PM
  #36
COSPEED2's Avatar
LS1Tech Sponsor
^ those links are correct.
If you still want the LS7 lifter set, they are $99.95 right now
The Morel Drop ins (which can be had for a better price right now than the lunatis in this thread!) are HERE at ~$185.
You wont find em anywhere else for that price.
The other Morel options are HERE under the Brand.
Old Mar 20, 2014 | 01:03 PM
  #37
speedtigger's Avatar
Old School Heavy
People complain about the LS7 lifters because they are having valve train noise issues. Many people suspect their lifters have some type of short coming that is causing their valve train noise. So, these people are in search for another lifter that may solve their problem. It is not a catastrophic failure trend that is driving the market for lifter alternatives, it is noise complaints.
Old Mar 20, 2014 | 02:36 PM
  #38
COSPEED2's Avatar
LS1Tech Sponsor
Well that is not entirely right. There have been failures before and usually for above 6500 or aggressive lobes or a good amount of seat pressure, we recommend a different lifter.
Old Mar 20, 2014 | 02:55 PM
  #39
Old School Heavy
What? You mean there are limits to the capability of stock parts? LOL
Old Mar 20, 2014 | 04:11 PM
  #40
COSPEED2's Avatar
LS1Tech Sponsor
It is entirely possible that stock or stock replacement parts will fail before a higher quality aftermarket part will, but normally that failure can be attributed to improper setup or abuse. Normally.
Peace of mind can be priceless though.
Why do you think people spend so much money on engines from the higher tier engine builders? They use the same parts (for the most part). Quality is usually the answer.
