THE answer to your ls7 lifter woes.
Well, since not everyone has $500+ to spend on Morel's there has to be another alternative.
And of course there is. We have the Lunati drop in ls replacements avail and ready to go. They have been used in numerous reg and high horsepower builds to date. They are commonly overlooked as well for one reason or
They are superior quality to the ls7 and wont break the bank like Morel. PM for pricing. And you dont have to worry about being machinist precise on the lifter preload like some of the short travel lifters. They have a normal range just like the ls7s, which is good as every assembler/shop has their own preference.
I ask because it seems to be the trend here that a few 20 or so start talking **** about something... (Some of them have never even touched or used the parts their bashing.) Then they get every one else fired up and before you know it you have a whole thread of fail.
Not saying you are doing that I'm just curious if shops like yours are having real problems with the lifter of if its just individuals that have a cam thats too big, lobes that shouldn't be on that style of lifter, cheap springs ect ect...
Once again not trying to start a pissing match, I'm running LS7 lifters in the 3 LS engines I have had to open up for one reason or another and I haven't had a problem with any of them. My 5.3L just went over the 100,000 mile mark with LS7 lifters.
I would say most of the time the problem with the lifter failures IF indeed they were "ls7 lifters" and not stock lifters in the engine is from user abuse/neglect. After that is usually a question of installer error or improper lifter preload. Even using lower quality oil and filters can cause these issues.
This thread is not to say LS7 lifters are bad, nor did I ever say that.
This thread is to offer another alternative to them that are higher quality and a direct drop in. For some of the more aggressive cam lobes out there and higher spring pressures, I would be a bit wary of using LS7 lifters over a higher quality style.
Also using brand new LS7 lifters on a used camshaft....that is questionable also. Quite often the people trying to save money with budget builds often find themselves upside down in the budget when things go wrong. Using quality parts will nearly always equate to a quality build. I have yet to hear anything to the contrary. The LS7 lifters are good quality, but there are better out there.
My vote is for link bars, but they are not a part of this thread.
Does that answer your question? We dont just sell parts and make threads just to sell parts. We are also here to educate and give alternatives.
I'm sure Lunati makes a quality lifter. I have their voodoo crank in my car as we speak, great quality. I understand you are just trying to sell a good alternative to a stock component. I just wanted to hear what your issues were with the LS7 lifter.
If you read the threads you hear how leery some people are of LS7 lifters and really no one had an option save for $500 morels etc. So there does seem to be some issue on the boards, at least, talking about them. This thread is about them and others...not me.
You somehow seem insulted by my thread title? I am unsure of that. I have been straight forward and direct with each post and answer. If I did not have a true answer, I didnt write it. Just like the actual down and dirty technical facts behind the lifters themselves. Esp trying to get answers on a friday. So if you stay tuned to the thread, you can have actual facts on the lifters themselves.
I personally have seen quite a bit more than a few failures of engines. I am glad to say I have never blown up nor caused damage to an LS engine myself. Have I seen lifters fail? Yes. Can I say 100% that they were LS7 lifters? No. So I wont. In that respect I have no say. That works alot better for me than someone misquoting me saying I am bashing the LS7 lifters etc later on.
There were a few problems in the past with bad batches of LS7 lifter sets that were new, but that was about 4 years ago or so. I have not personally heard of bad batches lately and like I said previously, the damage could be from builder error or abuse/neglect but who is to really say. Paul Harvey is dead, so we will never know the rest of the story.
http://www.camaro5.com/forums/showthread.php?t=136468
http://www.lsxc.com.au/ozlsxforum/sh...Lifter-Failure
http://speedtalk.com/forum/viewtopic...31995&start=30
http://forums.corvetteforum.com/c5-t...r-failure.html
https://ls1tech.com/forums/new-ls1-o...r-failure.html
http://www.compcams.com/catalog/COMP...12_274-291.pdf
http://www.carolinahorsepower.com/fo...ad.php?t=11283
Quite often the trays will crack due to the drill mod that people are still doing to them. Ive seen that first hand.
You can likely bet that what I have gone over before is the biggest cause, BUT if there is any other cause such as the quality of the lifter itself, then again they are the next best option.
If they were easier on the wallet, I would have offered them as the first viable option, but they are a tad up there.
Here they are though.
If you want the peace of mind of using used lifters on a used cam...why not just use them on a new cam and have no worries?
Why not just used used lifters on a used cam?
The 454 has the high rpm lunati I rev this to 7500. Bigger wheels, better body material and much less preload is needed.
Tim
