ported ls6 vs tfs 215 vs prc 215
If you are planning on 2nd hand parts then you do have a budget. For the price the trick flows are hard to beat. In an arbitrary test that is.
For the price you paid in consumbles and time to swap cams twice because the first one was just to get you by, you could have saved up and got something that fit your endgoal. You dont HAVE to have it right now in most cases. But WANT trumps need more often than not.
I would be vary wary of parts that may have changed hands too many times. Parts wear.
Your Vette will be runnin' sub 11s for sure this year...probably 125-126 mph
ported ls6 heads or
TFS 215 without additional work
PRC 215 without additional work
TFS As-Cast heads, hand ported by Tooley with PM guides and LS3 valves. Cheaper and better than anything listed in this thread.
The TFS as-cast heads would be like $2100. With the same essential valvetrain. And the TFS heads are about $2700 with the PM guides and LS3 valves. I would never advocate the ported TFS heads when the as-cast with hand porting will match it for much less.
