ported ls6 vs tfs 215 vs prc 215
Old 03-04-2014, 06:27 PM
  #41
BrntWS6's Avatar
^^^ what's the power difference between your LS6 and as cast heads?
Old 03-04-2014, 08:44 PM
  #42
windmill's Avatar
with using the as cast heads vs the reg 799 heads how much more ptv clearance do they give? just wondering then i could have more compression cause I could mill them more...
Old 03-06-2014, 04:22 PM
  #43
LS1Tech Premium Sponsor
Sales3@Texas-Speed's Avatar
Between our stage 2.5 LS6 heads and the AsCast you can typically expect around 10 rwhp plus the benefits of going to the aftermarket casting. Such as a 3/4" deck surface for better clamping force and a raised valve cover rail in case you would like to run aftermarket rockers and don't want to run a spacer.
They're comparable to our stage 2.5 LS6 heads with about .010 more clearance on the exhaust. Though we do have small chambers that start at 62cc and we can mill down from there.
Lonnie
Old 03-06-2014, 04:23 PM
  #44
LS1Tech Sponsor
COSPEED2's Avatar
Milling the head will effect the flow.
Old 03-06-2014, 04:32 PM
  #45
Correct. Though our power figures and flow numbers are based off of the standard 62cc chambers. The gain from milling typically outweighs any loss in flow.
Lonnie
Old 03-06-2014, 04:36 PM
  #46
LS1Tech Sponsor
COSPEED2's Avatar
Up to a certain point at least.
Old 03-06-2014, 04:43 PM
  #47
Old School Heavy
speedtigger's Avatar
Performance for dollar, I still think these are THE BEST deal out there:
http://texas-speed.com/p-1391-prc-st...ted-heads.aspx
$1199 for 313 CFM. Hell of a deal.
Old 03-06-2014, 05:07 PM
  #48
Also, just an FYI, we were able to get over 300 castings of new 5.3 heads and can offer our stage 2.5 5.3 heads out right again and no longer require customer cores.
Lonnie
Old 03-06-2014, 05:12 PM
  #49
windmill's Avatar
Thanks Lonnie for the info.
Old 03-08-2014, 12:45 PM
  #50
possessedsaint's Avatar
well to throw a wrench in the equation ....im thinkin of now doing an lq4 swap....so ill have to take that into consideration with the heads
Old 03-08-2014, 01:52 PM
  #51
LS1Tech Sponsor
COSPEED2's Avatar
Originally Posted by Sales3@Texas-Speed
You can use stock components (rockers) on either of our PRC 215 or AsCast heads. We also offer stage 2.5 LS6 heads though for not much more $ you can step up to the AsCast heads to get into an aftermarket casting with 12° valve angles and a 3/4" deck surface.
Lonnie
Unless you use an over 600lift cam then just like trick flow you recommend roller rockers. No one says that though.
Old 03-08-2014, 02:27 PM
  #52
LS1Tech Sponsor
COSPEED2's Avatar
You are reading too much on the internet. Seriously just get something and go with it. The more you read the less you may learn.
Old 03-08-2014, 07:08 PM
  #53
The Scammer Hammer
dr_whigham's Avatar
Reading on the Internet is what built my first car.
Having said that, I see you're on a budget, like most of us are. Honestly OP, the first set of used (good used) aftermarket heads you run across on here I'd scoop them up and have a cam spec'd around them. That's what I did.
I already had the cam in the closet, but the heads I just so happened to come across (AFR 205's) worked well with them. It was custom spec'd from Ed Curtis.
Old 03-09-2014, 04:14 AM
  #54
Quick Ranger's Avatar
Tigger- Are you running these heads with the stock valves using the nitrous? They aren't a bad deal, just add some BTR springs.
Old 03-09-2014, 12:35 PM
  #55
id rather gain as much info as i can before the build.
Old 06-04-2014, 03:55 PM
  #56
SoFla01SSLookinstok's Avatar
I mean, you gotta understand what your reading about, but you can learn a lot on the net. I mean just doing research myself i'm so glad I went with the PRC 215 heads. I was about to go for the stage 2.5 or stage 3 LS6 heads. For a bit more I got the 215's. I'm surprised there are'nt more vouching for the PRC's. They are awesome heads!
Old 06-04-2014, 04:31 PM
  #57
LS1Tech Sponsor
COSPEED2's Avatar
Quite a few people including reputable shops around the country dont post on the net. You can also get lopsided experience as well. Hence you shouldn't always believe all of it.
Old 06-04-2014, 04:37 PM
  #58
Old School Heavy
Yes. Those are the heads that I am using. I just think they are one of the best bangs for the buck out there.
Old 06-04-2014, 06:51 PM
  #59
Quick Reply: ported ls6 vs tfs 215 vs prc 215
