LS6 with ETP225 heads
Old Mar 5, 2014 | 04:54 PM
VeryWhiteDevil's Avatar
Default LS6 with ETP225 heads
I plan on running GM gaskets and I know due to running the larger heads on the 346 that you are supposed to run the larger head gaskets. so, what is the best option here?? LS2, LS3 or LS9 head gaskets with cost not being the factor..
Old Mar 5, 2014 | 05:18 PM
Burken01's Avatar
Go with a gasket who's bore is .030 more than the head bore..
Ls9 is overkill @ 4.100 though it would work as well, mainly it's used for FI since its 7 layers
I'm using 4.030 bore cometics on my 3.906 iron Ls
Old Mar 5, 2014 | 06:56 PM
redtan's Avatar
Cometic 0.040 for better quench
