Intake Manifold Gasket, Which Should I use???
I'm going to remove my intake manifold from my 99 z28 because my knock sensors have gone bad. I was told that I have to change the the intake manifold gasket. My question is which gaskets to buy, which do I need I checked on ebay and there's various one's and they all look different.
http://www.ebay.com/itm/FELPRO-MS-96340-Engine-Intake-Manifold-Gasket-Set-/370989520303?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ALS1&hash=item5660b2d5af&vxp=mtr
http://www.ebay.com/itm/Fel-Pro-Gaskets-Manifold-Intake-Stock-Port-Chevy-Pontiac-SBC-LS1-Set-/191078329580?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c7d27ecec&vxp=mtr
http://www.ebay.com/itm/Fel-Pro-Gaskets-Manifold-Intake-Composite-Printoseal-Cathedral-SBC-LS1-Set-/191072163812?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c7cc9d7e4&vxp=mtr
The first gasket is for a 2.2 engine, the center pic is for an LS1/LS2/LS6 engine and the last pic is for an LS1,2&6 with an aftermarket aluminum intake manifold.
And get a knock sensor jumper harness, as water gets into the knock sensor wells & corrodes the harness terminals. GM has a TSB about creating a water dam with silicone around the knock sensor wells to keep water out.
Russ Kemp
Russ Kemp
I bought the MS92438 kit off Amazon for $22 with free shipping. It fit nicely. Pictures of the oring intake port gasket can be seen here in post #11.
https://ls1tech.com/forums/conversio...rag-strip.html
