engine shaking...normal???
Old May 13, 2004 | 10:20 AM
badazzhawk's Avatar
Default engine shaking...normal???
i jus installed the tsp231/237 cam...my engine is shaking more since stock...at idel...is that normal...or does it jus need a tune...and wold a 160 themo...help or jus keep the temp stock..thanks
Old May 13, 2004 | 10:21 AM
foff667's Avatar
LS1TECH Sponsor
need a tune probably to raise the idle...otherwise youll shake the mounts to an early death.
Old May 13, 2004 | 10:50 AM
badazzhawk's Avatar
Default ok
thats what i was worried about...the mounts...but tunning should fix...or at least the idle...i havn't drilled the hole in the tb...would that help
Old May 13, 2004 | 10:54 AM
foff667's Avatar
LS1TECH Sponsor
yah...really you just need to raise the idle a bit so it smooths it out...that will stop most of the shake. Ive got mine set at 900-950 and have little engine movement
Old May 13, 2004 | 11:43 AM
hourang's Avatar
screw raising the idle, its gonna shake, its normal, leave the idle low and enjoy the sound of the cam
Old May 13, 2004 | 12:32 PM
General Jack's Avatar
I've got the x1 cam 230/227 112 lsa, and it shook one of my main water lines off. Small price to pay...
