Need help selecting a cam
So far the car has long tube headers, full exhaust with no cats or O2 sensors(will be putting a couple of O2's in) Just picked up a set of machined 241 heads, this is the sellers description -""This auction is for a set of LSX heads. They are off of a 2002 Camaro and are assembled with Blue Stripe comp 918's with 3000 miles on them.
The heads were milled .030 (62cc), 2002 intake valves (2.00) and 1998 1.60 exhaust valves with a lot of bowl work and blending. The runners are unported. Flows roughly 255-260 cfm at .600 lift which is more than a stock LS6 head!
Unfortunately, I do not have a flow sheet. These are sold as is, no refunds and what you see is what you get. With a decent cam, supporting bolt ons and a tune your LS car should be well over 400rwhp without a doubt.""
~Also ordered a breathless cold air vortech intake. I do plan on getting a intake manifold, not sure what to get?? And just need help selecting a cam shaft for this if anyone can help! Thanks in advanced.
*Trying to do this build on a tight budget, would like to keep the 918 blue stripe springs for budget reasons. Really looking to keep the motor reliable, with a usable power range for street. Would like to have a low choppy idle(if possible), it is a automatic, with stock torque converter. Trying to get over 400hp to keep up/beat my dads 2010 Grand Sport Corvette.
Also I have the opportunity to buy a Cometic multi layer head gaskets with .051" thickness. Would this work well with my build?
Russ Kemp
