gen3 block with gen4 crank questions
Hey guys, I've got a brand new iron 6 litre block (casting no. 12576184) which from what I can gather is a gen 3 block. To go in it I have a rotating assembly from a ls2 (gen 4). Question I have is which balancer and timing cover should I use when mixing the two? And is there anything else I should look out for? Will be swapping the reluctor wheel for a 24x unit. Cheers
