valve spring shenanigans
Old Mar 11, 2014 | 11:24 AM
gear_grinder's Avatar
Default valve spring shenanigans
hi
i bought a set of "open box" GMPP blue springs on ebay. took them to the machine shop and they are exactly the same (pressure wise) as the stock lq4 valve springs that were in my stock 317 heads. my stock springs had a blue stripe on the bottom two coils. they both had an open pressure of 293@1.200
anyone know for sure what the lq4 springs are rated at for open pressure (1.200/1.250)?
thanks!
Old Mar 11, 2014 | 11:42 PM
.boB's Avatar
Yeah, the guys at Flyin' Miata discovered the same thing with their Targa Newfoundland car. Just because they're blue.....
A few months back I got a good deal on some blue LS6 springs, thinking they were a higher spring rate. When I tested them, they're the stock LS1 spring rate. Still a good spring for a mild to moderate street car, though. As long as you're not bouncing off the rev limiter every lap, or using a high lift cam, they'll be fine.
But, I'm building a track car that's going to see 6,500+rpm's pretty often. I picked up a better set of PAC beehives on a recent group buy.
Anybody want to buy a brand new set of magic blue springs?
Old Mar 12, 2014 | 08:45 AM
thunderstruck507's Avatar
when I was a newb here an ******* sold me a set of worn out stock ls1 springs in a comp 918 box...some people need a kick in the teeth
a former sponsor here at the time did me solid and hooked me up with a set of PAC springs for a discounted price
Old Mar 12, 2014 | 02:58 PM
01ssreda4's Avatar
Never heard of these. Can someone post a pic of them?
Old Mar 12, 2014 | 03:07 PM
TurboBuick6's Avatar
They are a new color. It is what the ZZ4 fast burn "604" crate motor uses. Just the current OE valve spring.
