Timing chain -LS2 or Cloyes
Is there an advantage running this vs. the stock LS2 chain/gears other than being adjustable? I'm assuming I wouldn't have to worry about slack. This is not much more money than stock chain/gears.
Thanks
I run the LS6 damper and a Rollmaster double row chain. Very precise timing and no slack - Cloyes with hexajust is even more precise and easier to use. Cloyes also takes out the slack as the chains are hand matched to the gears.
I'd have to pick up the Trick Flow dampener adapter bracket and LS2 dampener in order to run it on my block. I understand the purpose of the dampener, but if you remove most of the slack with the Cloyes set, compared to what a stock LS2 timing set has, is the dampener really necessary, or just recommended?
I got the same set, it's a good deal @ $110 shipped.
You don't *need* the damper, it's just nice to have. I opted to go with a c5r chain, cloyes timing set, and an ATI superdamper.
My car is a street car. I would probably get struck my lightning before I would break a chain in this car.
If I were you, I'd take the money towards the damper, and see if you can find an ATI superdamper instead. A lot of times they sell ones with minor blemishes on ebay for $215, that's how I got mine.
Everything really depends on how you run your car.
The Cloyes is a good deal, and I expect it to be better than a chain with stock gears.
Apparently, it's that rapid engine deceleration that gets you. One side of the chain gets tight, and the other side gets a little slack in it. that's when it whips around and bad things happen. With a good chain, you're not likely to break it. But it will stretch and wear a lot faster. And there goes your valve timing.
I've been road racing a SBF for the last decade. I tear the engine down every two years at a minimum. I use the best chains and gears I can find. Unfortunately, the SBF does not have any support for the chain. Every time I tear the engine down, that high quality/expensive chain is stretched out and floppy. I spend nearly $200 on new gears and chain with every tear down.
Personally, I plan on spending those small bux to prevent that from happening in this engine.
That was from 2002, before the LS2 chain was out. Can anyone verify for sure that the older cloyes set now comes with an ls2 chain? I know they stopped making the ls1 chain a while back.
Anyways here is a picture of the Cloyes vs. stock :
http://www.summitracing.com/parts/tf...5600/overview/
Lets hope not. Would defeat the purpose of having it.
