anyone with A tsp torquer v2 cam?
Old Mar 24, 2014 | 04:20 AM
  #41
AbsolvedJD's Avatar
I had a 228r, v3, and a VRX5(236/238 113lsa) but they were all in a LS2 GTO, and they were installed in that order. 228r had torque available the earliest but a very weak lope. It would probably lope a little better in a LS1. V3 had a kick in the pants rush of power at about 2500 rpm that was a blast and had a good choppy idle... It was my favorite cam. VRX5 had the same overlap as the v3, but it loped more possibly due to it being paired with Trickflow heads and a FAST 102. Not really sure why it loped more. The vrx5 sounded the meanest and had the weakest mid range. Power didn't seriously come in until 4500rpm but it was strong as a mother at that point. And when your banging gears you never drop below 4500rpm anyways.
The 228r tried to die constantly whenever you pushed the clutch in, even after taking it back to the tuner 3 times. It was annoying, but it was due to the tune. I replaced the 228r with the v3 because I wasn't happy with the 228r's smooth-ish idle and it worked out as the v3 still had good mid range power. The v3 actually had less parking lot bucking and surging due to having a better tune I'm guessing. The v3 bucked somewhat while cruising bellow 1500rpm in 5th. The VRX5 would buck pretty good up until 1500rpm while cruising in 5th gear... Then from 1500 up to 1800 there was intermittent, light bucking. It was kind of annoying because it was my daily driver back then.
In my ls1 Trans Am I now have a 228/236 112lsa with comp Xer lobes. Idle is a little choppy but not choppy enough. About to upgrade to a something bigger in the ls1 just for fun while I get a 383 going. It's a M6 with factory rear end and gearing.
The 228/236 cam that's currently in the Trans Am doesn't buck while cruising. But it does buck in parking lots (just like every other cam I've had), but only if you coast in first gear and let it decelerate to 1,000 rpm. When it starts to buck you just push the clutch in, let your speed decrease, and let it back out with some gas pedal and drive. It's very easy to get used to. Also, eery now and then the rpms will dip down when turning sharply into parking lots but it doesn't die. I just hit the gas a bit whenever my foot can come off the brake. It's all in the tune, but it's at an acceptable level to me so I've left it as-is. Some stuff can't be tuned out. My Trans Am isn't my daily driver so drivability isn't a big of a concern as it used to be.
Anyways, let us know what you decide and don't forget valve springs!
Old Mar 24, 2014 | 12:13 PM
  #42
MikeWS6's Avatar
If you run the TV2 I would get some 4.XX gears. The 228R is fine on the stock gears but anything bigger you may want to consider changing. Really cant go wrong with either cam.
Old Mar 24, 2014 | 02:53 PM
  #43
99yellowz28's Avatar
Well I talked to a guy at tsp and he had personal experience with the cams I was interested in and I explained what I was looking for so I ordered a torquer v3 111lsa with double valve springs
Old Mar 24, 2014 | 09:19 PM
  #44
SStingray's Avatar
Originally Posted by 99yellowz28
Is it pretty sluggish at lower rpms?
It's never sluggish. It just begins to buck around 1500 and then clears upcompletely at 1800. For me, this is perfectly normal for a cam that size. Normal driving it pulls out fine off idle. It only get finicky if you try to cruise down around 1500 prolonged. It is not meant for that.
Old Mar 25, 2014 | 12:00 PM
  #45
MikeWS6's Avatar
The T3 is a good cam. I almost ran it.
Old Mar 25, 2014 | 05:44 PM
  #46
thanks for everyones input i appreciate it
