anyone know this dash light?
Old Mar 13, 2014 | 07:00 PM
countryguy1717's Avatar
Default anyone know this dash light?
I don't have a manual and all the fluids seem topped up
Old Mar 13, 2014 | 07:06 PM
Bama99z's Avatar
Default Light
IIRC this is the radiator coolant light. There is a switch on the radiator below the radiator cap. the switch is either going bad, gone bad or dirty. Hope this helps.
Old Mar 13, 2014 | 07:33 PM
2002ss335's Avatar
If you need an owners manual just Google "1998 camaro owners manual" and download it.
Old Mar 13, 2014 | 09:13 PM
Can I pull the switch without draining?
Old Mar 14, 2014 | 08:09 AM
Paul Bell's Avatar
That's MISTER MODERATOR
Countryguy, this is the genIII internal engine section. Cranks, rods, oil pumps, etc.
Your question is a vehicle specific question and belongs in the Camaro section.
Old Mar 14, 2014 | 07:46 PM
Bama99z's Avatar
countryguy1717,Only if the coolant level is below the sensor outlet. The switch is a square switch.
Old Mar 14, 2014 | 08:26 PM
99Bluz28's Avatar
A lot of the time the sensor is just gooped up from crap in your cooling system, and it doesn't take much at all. I'd remove the sensor and clean it, that should fix it at least for a short while, or just unplug the it.
