needing more info on 285lr hr13 cam
I can't seem to get it to idle properly. my tuner says to open the throttle blade to about 5% so that it can idle but then others tell me that the tuner needs to control the idle.
Good luck tuning that one. I took out a 234/242 114 cam that had 10* overlap because I got tired of the low rpm/light throttle surge/fishbite. Since I have a manual trans, it would be less noticeable with a auto trans. I now have a 234/242/117+2 cam that has 4* overlap. The car drives 10x better, still has stupid bottom end, and gained mid range to top end power due to the earlier exhaust valve opening. I like my car again.
Russ Kemp
