Wtf is with cam bearings?!?
http://www.summitracing.com/dom/part...814s/overview/
clevite cam bearings and 3 of the 5 bearings are WAYY to tight on the camshaft, whats the deal with this, cant turn the cam shaft down because then there will be too much clearance in the good bearings, is it suitable to clearance the bearing with emery cloth etc? they are so tight to the point that I can not even get the cam through even with the bearing out of the block, the ID is about .01 smaller than the actual cam journal..
I've seen the cam fit tight inside the cam bearings and still ran the motor. Never had an issue. Same amount of oil pressure and no issues for many miles.
