Engine noise(w/ vid)
Old Mar 21, 2014 | 07:57 PM
jdtower23's Avatar
Default Engine noise(w/ vid)
Car was running fine when I parked it....few days later I come out to start it and this happens....
What ya think?
Old Mar 21, 2014 | 08:06 PM
HCI2000SS's Avatar
That doesn't sound good lol Is it louder up top of the motor or underneath?
Old Mar 22, 2014 | 03:03 PM
jdtower23's Avatar
Pulled the valve covers today and didn't see anything abnormal....so it's bottom end!
Old Mar 22, 2014 | 03:06 PM
HCI2000SS's Avatar
Sorry to hear that, but that's ususally not a good sign! I should know lol
Old Mar 22, 2014 | 03:25 PM
Fastdriver1992's Avatar
that sounds lovely sounds high pitched (top end) more then the bottom end. that is not a nice sound
Old Mar 22, 2014 | 03:37 PM
JRENIGAR's Avatar
Perhaps a collapsed lifter. Normally rods don't just spin while the engine is off. Id pull the valve covers back off and turn the engine by hand checking the rockers for slack. Hopefully you get lucky and its just a lifter that got collapsed while valve spring was compressed and it wont prime back up. My damn 2009 Yamaha Raider 1900 did this exact thing almost every time I started it.
Old Mar 22, 2014 | 10:46 PM
jdtower23's Avatar
Still not sure....couldn't see anything wrong with rockers when cranking it....seem tight just slight side to side movement.....car was also missing when running....guess I'll do a compression check next...
Thanks,
John
Old Mar 23, 2014 | 12:29 AM
Cajun ELESS-ONE's Avatar
bent pushrod maybe??
Old Apr 7, 2014 | 02:53 PM
jdtower23's Avatar
This may be the problem
Attached Thumbnails Engine noise(w/ vid)-10149026_621283074628579_18248943_o.jpg
Old Apr 8, 2014 | 09:38 PM
sepsis's Avatar
What is that?
Old Apr 8, 2014 | 10:55 PM
jdtower23's Avatar
Hole in the block above the starter
Old Apr 8, 2014 | 11:18 PM
Majestic9C1's Avatar
that sucks
Old Apr 8, 2014 | 11:19 PM
sepsis's Avatar
Had a hard time seeing it on my phone.
Looks better on my monitor. lol
That can't be good....
Old Apr 9, 2014 | 02:15 AM
Crimsonnaire's Avatar
Did the sound appear all of a sudden?
I will agree with JRENIGAR about keeping tabs on the lifter possibility.
Lifter taps seem to be the preferred suspect to taps over piston slap and whatnot, but after seeing this, I learned bad lifters are not to be taken lightly:
Learning from this guy's ordeal, I think it's best you minimize running the engine until you can rule this out.
Generally, is there a way to differentiate between a lifter that has collapsed/broke apart from a lifter that's simply worn with loosened tolerance? Either case will generate taps, but the first case could potentially destroy the entire engine with debris circulation whereas the latter can tolerate continuous service.
