What Valve Springs W/ VRX5 .605 Lift
Im putting my engine back together, and cant find a set of valve springs locally. I expected to make a trip down to Summit and buy the springs along with many other parts.
Vengeance racing recommends to use dual springs with the VRX5, but exactly what springs will work?
Cam specs
236/238 .601/.605 113+2
Something I came across
http://www.summitracing.com/parts/tfs-2500300/overview/
Cam specs
Anything over .600 lift I recommended dual springs. You can get away with singles, but with that high of a lift, they will wear out in a fairly short period. Just my 2cents.
Ok. Exactly what dual springs will work with my setup? I am using stock heads. I just hope Summit has a set, as that's my only option to get the motor together this weekend.
EDIT: Thanks Darkman, we posted at the same time. Ill see if summit carries them.
