What pistons to get? An short block tms
Looking to get one from tms Going with a 5.7 ls1. But have diff pistons I can pick from. Tms pistons hypereutectic 3.898 guessing they r stock pistons just be cleaned an checked, or Forged Probe pistons 3.902" Flat top -3cc
Everything else in the short block is the same l33 bored to a
5.7
The only diff is pistons an price which is $400.00 more for forged
The motor is n/a with 241 heads 92/92 with t-Rex cam. Do I need forged pistons?
Was staying with aluminum motor for weight. Thought about going with a 6.0 aluminum from tms but just don't see that much of a gain in hp/tq for the extra $600.00 for base hypereutectic pistons an would have to Change over stuff like cover an wire harness to work for a 6.0 (what I have read). On here.. Not for sure if that's true
Would it be smart to just pay an get forged pistons to have the guy on my shoulder saying it's somewhat stronger of a motor?
Dyno the car it's making 455hp/421tq at the flywheel on a dyno jet I believe (James short) ShorTuning Dyno an tuner. An when I did swap out short blocks I was thinking of getting the 241 worked over valve job, an ported and polished was like to make 500hp at the motor. Would I get 40-50 hp for getting the heads worked on?
Thanks an sorry for all the questions
Jason
Getting the 6.0 won't net you much more hp (if everything else is the same) but it will bring up the tq a little and bring it in sooner as well. Now the cool thing is with that T-Rex cam it would be more suitable to that 6.0, and if you port the 241's it will really shine! I say get the forged LQ9 and don't look back! This was my dilemma at first as well, but i'm so glad I did! Also TMS is a awesome company to deal with!! Here's the short 6.0 ls2 I was looking at for 2,600
TMS Hypereutectic Piston set 4.000"
TMS Moly Rings
Blueprinted NEW GM Gen IV 6.0 Aluminum (LS2) block
GM Floating Connecting Rods remanufactued
GM Crankshaft Polished, Chamfered and Balanced core
King Racing Main and Rod Bearings
Thompson Motorsports one piece racing cam bearings
**This Short Block is rated to 450HP**
Are get a iron ls2 370 ci for 2k. Save $600 but add 100lbs to the front end. Mmmm
Piston to valve shouldn't be any different if using a stock LS2 because they use the same size crank rods and piston height as an LS1. The difference would come in with what heads you decide to use with the combo. If you went to all the trouble I would just flycut the pistons anyway. If done properly it doesn't hurt the integrity of the piston.
As for heads unless you are doing the AI 241's I would leave them on the LS1 and score some 243's and have them worked. I did a stock 241 to TEA CNC st2 head and average gains are right around 40rwhp on them. Stock 243's will gain you ~15hp over stock 241's. I would look into a fast intake prior to spending the bucks on porting heads. With a TREX cam the gains won't be as good over the 241's. The cam holds the valves open so long it's filling the cylinder even though the head doesn't flow as good. So adding a head that flows more isn't going to help a setup out as much that is already filling the cylinder. It'll still help just not as much as someone that has a 228 cam or similar.
If you shop around the 243/799 can be found reasonable. I could probably help find a set for you.
my goal is 500hp at flywheel so when the ls1 is die I'll have the 6.0 an 243/799 ready to just drop in an have my goal, I Hope that is .. Do u think I need to have the 243's worked on just a little bit? To get 500hp? I asked tmp about what block they use he didn't answer me. but said he would sale me the 6.0 for 3k but with my ptv Clarence I would need the forge piston. I told him I'll just save the money flycut the others pistons. an still didn't answer what block they use. I'll just have to wait for that answer I guess, on the block U still have my number James? If u do find any heads for a fair deal just let text me or fb me.
