cnc 243 heads identification
Old Mar 23, 2014 | 11:05 PM
Andz33's Avatar
Default cnc 243 heads identification
In need of some help trying to figure out who did the cnc work on these heads. I picked the up from a member on here and he thought they were prc ls6 2.5 heads, but didnt see any etching of prc anywhere. One of the heads has a H and the other has a K in one of the chambers. It also has EE etched on the opposite side of the casting number of the heads. The heads had a ton of work done to them from bronze valve guides, ferrera valves and patriot gold dual spring. Any information would be appreciated.
Old Mar 23, 2014 | 11:26 PM
Andz33's Avatar
The value part number are F6703 and F6704, but I can not find them on Ferrea website as well.
Old Mar 28, 2014 | 08:25 AM
Andz33's Avatar
Anyone? I found out the valves were private production valves for Patriot Performance. The bronze vavle guides are patriot performance as well. Does HKE in Houston Texas do CNC work on heads?
Old Mar 28, 2014 | 08:37 AM
Rise of the Phoenix's Avatar
That's what I was going to suggests; HKE. I do believe they do head porting. Maybe give them a call and ask how they stamp their heads.
Old Mar 28, 2014 | 09:08 AM
07bluelbz's Avatar
Cartek maybe?
Old Mar 28, 2014 | 09:20 AM
Andz33's Avatar
Would you believe they are patriot heads being the valves are private production for patriot only. Ill try and give both companies a call. Thanks for the help guys.
Old Mar 28, 2014 | 10:46 AM
brandonk's Avatar
nice!
Old Mar 28, 2014 | 10:51 AM
KCS's Avatar
KCS
Moderator
HKE doesn't CNC heads, the H and the K in the port are cast in there from GM.
Old Mar 28, 2014 | 11:36 AM
Andz33's Avatar
I contacted HKE and Erik told me the work wasn't done by his shop. I have never see those casting letters in any of the other heads I've owned.
Old May 28, 2017 | 01:34 PM
fastcars95's Avatar
I know its an old post but
did u find out what heads you have . I have the same stampings on mine E E
I was told they were PRC 3.0 but I'm not 100% postive
Old May 28, 2017 | 02:37 PM
cookseyb's Avatar
I had my 243's done by Patriot in Alabama, they do CNC valves and sporingsthey look good...
Old May 28, 2017 | 09:10 PM
30thanniv's Avatar
I had TSP do my heads and purposely told them to leave the 243 on and not etch their logo on it. I am not sure what if any markings they have added.
Old May 29, 2017 | 04:07 AM
07NBSChevy's Avatar
It does make things more difficult when a company removes the casting number from the heads and etches their own Logo in its place. TSP-PRC did my 243 heads and removed the "243" from both heads and I now have a fancy etched "PRC" logo there.
Now some heads have what appears to be a serial number stamped on the exhaust flange side, I wonder if that number can bring up what casting they are.
Old May 29, 2017 | 11:18 AM
OLDWS6's Avatar
That really makes it nice when you want to sell them and can't prove that they're not 241's.
Old May 29, 2017 | 08:49 PM
HCI2000SS's Avatar
I have the older style PRC 5.3 heads from Texas Speed and it has the 862 casting number stampted on the head. I was told some of the newer 5.3 heads by them just have the PRC on them.
Old May 29, 2017 | 09:56 PM
brandon6.0's Avatar
id say the hell with it and run them. Trying to find who ported them is like finding a needle in a haystack. A lot of diff companies do ls head porting. They look to have been ported really well. If u anything I would have them flowed and check cc's.
Old May 30, 2017 | 02:56 PM
fastcars95's Avatar
Mine still have the 243 stamping but on the other corner they are Stamped E E like op posted.
They made some good NA power but I removed them for some LSA square port heads and a turbo.
Old May 30, 2017 | 03:48 PM
So did you ever find out who ported them?
Old May 31, 2017 | 09:31 AM
axe murderer's Avatar
I have a few sets of CNCed 799s from a shop in MI, the 799 is milled off the top but there's still a 799 on the underside.
I believe they might of been GM blems, I think it was common @ 1 time for places to use GM 2nds.
Old Jun 2, 2017 | 12:21 PM
gagliano7's Avatar
I have 4 different sets of heads at home and they all have the # stamped inside the head in the middle above the head bolt under the rocker stands. Here is a pic of 706 heads. It actual has the # 1706. My 317 and 243 heads have the same thing.
