flycutting stock pistons
Old May 14, 2004 | 09:18 AM
DALLAS's Avatar
Default flycutting stock pistons
i want to learn how to flycut pistons on an ls1 to fit these larger cams like the trex, in case i have to. i heard you can do it by pulling the heads off and keeping the block in the car. any input?
Old May 14, 2004 | 11:12 AM
felton316's Avatar
You need to rent the Isky fly-cutting tool. It allows you to do it with the pistons still in the block.
Old May 14, 2004 | 06:02 PM
DALLAS's Avatar
where can i rent this tool from. will i need any other non common tools. how deep will i need to cut. how far can i cut. how do i know where to cut at?
Old May 14, 2004 | 10:22 PM
foff667's Avatar
LS1TECH Sponsor
i saw cartek do it at their shop...not sure which tools they use but they basically look like 2 valves with carbide ends...they used an old head for use as a guide and an air drill to just cut enough out of each piston...pita job but it works but then they pull the motor for crap like that.
Old May 15, 2004 | 12:23 AM
GTA91's Avatar
Where can someone "rent" this tool??
Old May 15, 2004 | 02:22 AM
DALLAS's Avatar
i've seen the two pieces on www.iskycams.com, the notching pilot and the notching cutter. which ones do i need? they have several different part numbers. so then i need an old head i guess? how do i know how deep to cut? how do i guage how far i am cutting? someone said something about needing clay, but didn't say what for. i am guessing that i would use the clay to seal off the gap between the edges of the piston and the cylinder walls, to keep out the metal shavings, correct? i still need alot more answers
Old May 15, 2004 | 12:19 PM
ForceFed HP's Avatar
Suspended Sponsor Account
we rent the complete setup here are the details
https://ls1tech.com/forums/showthrea...highlight=ffhp
Old May 15, 2004 | 08:15 PM
AustinL911's Avatar
the clay is used to check the piston to valve clearance after you cut, to see how far you've cut, and if you need to cut more. quick synapsis: slap thin peice of clay on piston where valve would hit, put on head, snug it down. turn engine over one complete cycle(2 turns on the crank) pull head off, measure how thick the smushed clay is.
