my new set up
Please input on any thoughts or other ideas you may have on these set up.
EDIT: the car will be sprayed with at least a 200 shot
EDIT: Ok so I guess i do have 241 heads...never realized they were pretty much the same head...still learning on this car.
The car will be a car to bring out here and there on the weekend and the drag strip. HCI2000SS: How much bigger woould you suggest? Not wanting to have to fly cut or anything. Open to any suggestions as I am not ordering a cam until I am for certain on one.
99Bluz28: the reason for the cam is of course the 200+ shot, as well everything I have read on this cam has been great and no real issues with it, as well as have seen some great numbers put up with the cam.
I'd contact Allan at Futral , and Kip at CamMotion and see what they would recommend.
It is a 10 bolt rear end...I know I know its on the list to get changed out soon! I know it can be hit or miss with that rear end but mainly miss. The bottom I got a ported ls6 oil pump and LS2 timing chain. Or rather that is what is suppose to be there with "upgraded" pistons and rods. Thats what the guy said when I bought the car, but never had it torn down to actually see. So will find out here soon.
I am not in a huge rush or anything to get the motor done so as things come up that I noticed need replaced or what have you or "beefed" up it will be thrown into the build.
Thanks for all the advice and suggestions everyone!! If you have anymore please let me know. I got the numbers to call around tomorrow about getting a bigger cam definately now.
I thought maybe you wanted something more mild based on what you described in your first post, but IMO this cam will be much more fun
after talking with CamMotion and thinking about it more, I realized how much I won't be driving on the streets and how much I will be driving on the Drag strip. I agree I'm excited to get the cam! now to get to work on the heads. Got them bare cleaning them tomorrow and take them to the shop!
Just have to get the rockers and lifters. For beehive single valve springs a set of PAC-1211X(about$200), and you can reuse the stock retainers, or if your budget permits a set of light weight tool steel (Comp Cams #1772-17, $150-$160) or titanium (about +$90 ) retainers.
I take it this is not a daily driver? If so, and it were me, i'd go with a slightly bigger cam since you're getting the heads worked over
