Operation super sleeper....
Old Mar 29, 2014 | 12:12 PM
99Bluz28's Avatar
Yeah your best bet is to focus on a cam with spec within this range: 218-221 for the intake lobes, and 228-230 for the exhaust lobes, and a 117 or 118 lsa to help keep the overlap in the -8* to -12* range I'd stick with a fairly mild exhaust lobe for a quieter(stealthy) valve train.
You're most likely looking at a custom cam.
Old Mar 29, 2014 | 06:39 PM
redtan's Avatar
Not set on anything! Just want a 20-35 hp gain and 0 change in idle.
A high 220s cam will have a different idle that stock, most gearheads will be easily able to tell you have a cam.
Old Mar 29, 2014 | 11:44 PM
99Bluz28's Avatar
Normally Yes, but not always. You might be able to tell by the sound if a engine has a performance cam in it or not, but not size/duration of the cam. You can have 2 cams with exactly the same lobes, lets say a 227/227 but one with a 110lsa and the other with a 118lsa. The 227/227 110 lsa cam will have 7* OL and a very clear cam lope , and the 227/227 118lsa will have -9* overlap and have a almost stock like sound. These two cams will not sound the same at all.
Old Mar 29, 2014 | 11:54 PM
A.R. Shale Targa's Avatar
Originally Posted by Mavn
Have you had it at the track or dynod it? Of not how's the butt dyno? Lo
based on 119.85 trap speed I'm probably at or near 380 rear
Old Mar 30, 2014 | 01:13 AM
Mavn's Avatar
"I MAID THEESE"
Got my 5.3 short block!
Old Mar 30, 2014 | 06:20 AM
redtan's Avatar
If you're going with a sleeper setup, why did you go with a 5.3 and not something bigger that will make more power and look just as stock?
Old Mar 30, 2014 | 09:22 AM
Mavn's Avatar
"I MAID THEESE"
Got the 5.3 for free! ^
Old Mar 30, 2014 | 10:57 AM
GMRL's Avatar
I see your a fellow Texan!
I would at least try to paint the short block with some silver or aluminum looking paint while its out.
Old Mar 30, 2014 | 11:18 AM
Mavn's Avatar
"I MAID THEESE"
Yeah will do! Gotta clean it up tho! It's a dirty ****** lol
