spec my custom cam
Old Mar 29, 2014 | 07:12 PM
monte383sbc's Avatar
Arrow spec my custom cam
spec my custom cam
98 ls1 full weight as of now
347 cubes forged bottom end, stock crank, ls2 rods mahle -4cc pistons 11to1compression
prc ls6 2.5 heads 2.02 intake valves 1.57 exhaust valves
edelbrock super victor intake
4150 750cfm pro systems carburetor
jesel j2k 1.7 ratio rocker shafts
comp R hyd lifters
kooks 1 7/8 lt headers
slp timing chain
slp oil pump
th400 trans
3800-4500 converter '' did not purchase converter yet''
moser ford 9'' rear 4:10 gears
28'' tire
150-250 shot of nitrous at the track but the car will see allota n/a street racing also
so who can spec me a cam for my set up and possibly a converter, thanks matt
Old Mar 29, 2014 | 07:18 PM
HCI2000SS's Avatar
Would you really rather have one of us here in the forums spec you a cam, vs one of the vendors on here who do this for a living lol?
Old Mar 29, 2014 | 07:53 PM
Sales@Tick's Avatar
Seeing as it's a single plane combo, I'd lean towards the 4500 rpm side of your stall converter range. The single plane will shift the torque curve to the right of the operating range versus a longer runner intake.
Running roller rockers and aftermarket lifters I would run more lift than I would using OEM lifters and rocker arms. Especially seeing you have aftermarket heads. A softer ramp is beneficial in my opinion with a roller tipped rocker. Roller tipped rockers tend to have more mass placed over the valve than an OEM rocker arm. Soft ramp and more lift aren't always used in the same sentence, but there are lobes able to do just that.
Depending how often you plan to use your nitrous will have an impact on how the valve events are arranged to give best performance.
If you'd like to know what I'd spec for your combination feel free to give me a call on Monday or some time next week. I'd be glad to help.
Old Mar 29, 2014 | 07:55 PM
I will have a vendor build me a custom cam iam just feeling the waters right now to get ideas thanks
Old Mar 29, 2014 | 08:38 PM
speedtigger's Avatar
Old School Heavy
There is an EPS single plane can for sale in the classifieds. Probably just what he doctor ordered. If memory serves, it is 236/248 on 110.
