Who wants to test a Low Lash Roller Cam?
UNDER PRESSURE MOD
If you're looking for another setup, specifically aftermarket heads with a different rocker setup, I have PI/Mast heads, forged ls6 block/bottom end, and a D1SC. I can give specifics about my setup, like the current pushrod length.
You should mention to those who aren't familiar, that to change the lifters, they need to pull the heads, so it's not just a simple cam swap.
We have been working on this solid lifter project and have discovered a problem that was not quite apparent at first. We have made cams for the LS Chevy since they first came out and I have worked on and built many engines and many kinds of engines since the 60’s but never any Chevy LS. I started collecting the parts and information needed to do the conversion and discovered some big problems with the stock cylinder heads. We were going to make adjustable pushrods and there is no room to get the wrenches in to make adjustments and no way to modify the head to accomplish the adjustment. We were trying to do this with just a cam, lifter, spring, and pushrod change but to make this happen there will have to be a rocker arm change also. We will need to use a rocker that has an adjuster on the push rod end, which means we will also need valve cover spacers or taller valve covers. We are still working on this project and will keep you posted on the progress in the next few weeks. The extra cost of the rocker arms and valve cover spacers will be offset somewhat because the solid roller lifters are less expensive than the good aftermarket hydraulic roller lifters. I will keep you posted. Kip
Interesting in what you are trying to achieve.
Amazed in that you have never built an LS engine but have built many of the older engines.
Guys have 'my self included' had an LS engine built by a reputable engine builder only to have ended with a disaster due to a non experienced LS engine builder.
My guy had 30yrs experience, only LS engine he had done was mine...HUGE FAILURE.
#34
We have a solid roller going in a engine this weekend. I am sure it will not be ready this weekend but it is going together. I am having a little trouble getting some Yellow Terra adj rockers from the WD. If I can not get them in time I will use Jesel’s for the test. I wanted the less expensive rockers. I will keep you posted.
#37
I was wanting to use the YT adj because they are less expensive than Jesels. I would like to make the solid lifter package was close in price to the HYD package. We will see soon. As far as the spring presser we are using just enough for control.
#38
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I used those the first time around in my set up. Got less than 1000 street miles on them before they started to let go and comp would not honor their "lifetime" warranty. Was running high 400's open pressure on them.
