Need advice on LS6 clearances: Bent Valves
Old Mar 31, 2014 | 09:27 PM
nmckeever's Avatar
Default Need advice on LS6 clearances: Bent Valves
Hey guys,
I have searched endlessly and have not been able to find an answer to my question. Replaced the LS1 in my car with an 04 LS6 block and stock 243 heads off a 05 GTO. Ordered the same cam I had before from Vengeance Racing (VRX5). However vengeance has increased the duration specs a little (now .601/.605 236/238 113 lsa insead of 232/236). I used stock .051 head gaskets, stock length hardened pushrods, and dual valve springs with my stock rockers. Made 4 pulls with my tuner (redline set at 6900) and about 50 miles later the car started acting up with reduced power so i got it towed. MAF failed (which i assumed was the issue for it running like ****) but when the valve covers were pulled i had one broken valve spring and a bent valve. So pulled the heads and discovered all the valves were bent and had touched the pistons. Car ran great while tuning and started acting up cruising on the highway. Is this too much duration for the stock specs?? I'm assuming the clearance issue is occurring with the valves floating when touching the rev limiter. Should I go up a size in head gaskets to be safe? Thanks in advance for any advice
Old Mar 31, 2014 | 09:33 PM
LLLosingit's Avatar
You need to know what your PTV clearance is, Guessing is never a good idea and you may end up with bent valves again. Might as well check it when you put it back together.
Old Mar 31, 2014 | 09:34 PM
poltergeist 02's Avatar
What valve springs and are they new?
Old Apr 1, 2014 | 09:22 AM
nmckeever's Avatar
Valvesprings were brand new PROMAXX 8401s
http://m.summitracing.com/parts/pmx-8401
Old Apr 1, 2014 | 09:56 AM
Exidous's Avatar
Those look a lot like the Patriot Gold duals. Was the LSA the same too? That's a lot of cam to not flycut or at least verify PTV. 2* is a LOT when you were probably really close to begin with.
Old Apr 2, 2014 | 06:51 AM
Ron@Vengeance's Avatar
OP,
Sorry to hear about your issues. Our VRX5 has always been a 236/238 @ .050... That being said, we have verified ptv NUMEROUS times on many applications with no issue.. Our Vindicator is a 240/244 duration @.050 and it clears, although it is tight.
My money is on the springs floating excessively.
Old Apr 2, 2014 | 07:01 AM
Darkman's Avatar
ProMaxx Performance 8401 - ProMaxx Performance LS Series Gold Dual Spring Kits Details
LS Series Gold
Gold Spring Specifications:
Install Height: 1.800"
Max. Valve Spring Lift: .650"
Coil Bind: 1.090"
Spring Pressure Closed: 135 lbs @ 1.800"
Spring Pressure Open: 375 lbs @ 1.150"
