Bearings
Old May 14, 2004 | 05:59 PM
stevieturbo's Avatar
Default Bearings
I have just taken the crank from my LS6 block.
The bearings are slightly marked, but not bad. They have the markings on the underside.
A-400
10 00
Is this a std size bearing, or is it suggesting that the crank has been ground ?
I measure the main journals at 2.555" / 64.9mm
I measure the rod journals at 53.25mm / 2.0965"
both using digital verniers
This was on a parts of an engine I purchased second hand in the UK. I do not have any rod bearings for part numbers either.
I want to buy new bearings, but need to know what to buy.
Thanks, Stevie
Old May 15, 2004 | 10:18 PM
98 Silver Bullet's Avatar
Production crank main journals are 2.559 and the rod journals are 2.099. You want standard bearings. I had my crank polished and ended up with .018 clearance on the mains and around .020 to .022 on the rod bearings with standard size bearings.
