Shop called, wat kind of damage have you guys seen valve stem seal springs do to car
Y wasn't I told the tech heard a noise
1 before he started working on it that way they could cover themselves
And
2 when I called about picking it up and was said it will be ready in 30
And
2 The tech probably put the car together and noticed that the noise was more pronounced than before and pulled the valve cover back off to investigate. JMHO. Eric L
Maybe true but leaky header and engine knock from bearings should be easily destinguishable to a tech......yea the replaced them......I'm not laming them but not ruling it out......I might take it to gm when it gets here......don't knock sensors hear stuff like this
My guess is they didn't find a problem until after they did some of the work. When they told you it would be done in 30 minutes I would assume the motor was still being worked on and after they completed the work they fired it up and found there were more problems.
