Which piston to order Wiseco or Mahle?
We only received two pistons out of 8 to look at. No pins or rings either, which doesn't give us much to go off of. The small area outside of the pockets was cracked due to a lean condition in those cylinders. Would another out of the box piston have fare better? No, and most wouldn't hold up even "as long" if they were 4032. That being said, the piston could have been prepped by the engine builder a little better and it would have held up a little longer under the lean condition....Hopefully long enough to spot it.
So what is considered a proper level piston preparation and who's responsibility is it? We live in the day and age of 1200whp crate/street engines that don't get the level of prep they did 10 years ago, yet 99% of the engines built are fine with an out-of-the-box piston. So how do you keep from being the 1%?
Anyone who's ever spent time prepping a piston will know the conundrum of "how much is too much" relieving in this area. The more you pull it back, the more it thins the ring land directly above the ring.
As a manufacturer, we leave as much material as we can out there and still provide adequate piston valve clearance (way more common problem with catastrophic results compared to flaking reliefs). A good rule of thumb is to have at least 2mm worth of material outside the perimeter of the intake pocket. This amount material is enough to hold up even under low level detonation and lean conditions. If it's less than 2mm, we drop an end mill down in there to relieve it further. This helps, but still leaves two other points and it's still not a miracle cure. Even if it's perfect, it's still the thinnest area of the crown and will be the first area to go when a cylinder is lean.
So what else can be done by the engine builder to help further? No matter which manufacturer's piston it is, an engine builder can cartridge roll this area back. If you do it once, you'll know what a proper "nub" looks like. It requires a steady hand, but even a beginner can do it if they're careful. Deburr afterward to keep the resulting flashing off the cylinder wall. It's an hour worth of work, so the engine builder that does it (and charges for it) is rare.
As a personal note, we produce pistons for most of the top LS engine builders. Most of the engines built on this forum use out of the box Wiseco pistons. We appreciate your business and constantly work to provide the best piston. A lot of guys on this board know they can always contact me and I'll do my best to keep them out of trouble to begin with and help them out if they do have an issue even if it isn't the pistons fault.
Again, apologies to the op for sending the thread off on a tangent.
Oh yeah, and the TUNE. Some people think that their tuner is beyond reproach. Well we are all human and we all make mistakes. Mine is getting out of bed in the morning.
You cant imagine the problems that internet viewers never get to see on here. Not everyone runs and posts.
The tractor isnt using the power pak pistons, like i said they are custom stainless, showing the capability of their company.
Is it typical to need a freshening within the milage you stated with 2618 pistons VS. 4032 s ? What are the benefits of the 4032s? Is that the low expansion piston Mahle sells? If so, wouldn't that be fine for a 95 % street car? Thanks in advance.
Jim
