lq4, which heads would you run?
03 Lq4, stock displacement
9.6:1
diamond pistons
eagle rods
stock crank
morel 5206 lifters
brute speed blower cam
Dur @ .050 232 int 240 exh
Lift .595 int .608 exh / 115 LSA
stock rockers with trunion upgrade
Edelbrock victor jr
Holley 750 HP carb
9.6:1
diamond pistons
eagle rods
stock crank
morel 5206 lifters
Edelbrock victor jr
Holley 750 HP carb
into the 10.25-10.5 range depending on the head gasket thickness.Assuming
flat tops of coarse.
The transmission type, converter stall, and rear end all play a role in robbing
power from the hot air pump but 425-440 rear wheel is not at all unrealistic.
We can get you whatever you need, and we also have some new as cast and cnc ported head options that are very competitive on price and flow numbers.
Also your carb may not like that cam too much. If you havent already bought it, id look at a little different one.
It would make quite a bit more power than a run of the mill ported 243 head, and have plenty of sturdiness for the supercharger later. Run 10:1 or a tad more and have fun either way.
The stall does seem a tad high but that is usually a matter of personal preference. If it does not have a lockup it really doesnt matter anyway in that regard.
What is your PB now?
I have seen some guys get "burned out" when their build didn't make the power they had expected because they were planning for future upgrades.
Normally used cams sell for 250-275 dollars. If you can recoup 250-275 dollars on your old camshaft then that would be a good start towards a new grind. I kind of look at it as you got great use out of a part that helped tie your combo together to be more optimal for 125-150 bucks.
I'd also suggest the single plane if you do plan on forced induction later on as it will provide better distribution under boost. It could be argued that you could change the intake just as easily if not easier than the cam which I would agree with also.
So, that choice is left up to you!
The intake I had no idea about, I appreciate the heads up on that. Even if I sacrifice a bit now I can handle that if it pays off once it has a small amount of boost. I know you guys are the experts and I appreciate fully this caliber of insight and help.
I'm going to look into this trick flows too, I know heads are where power is made and I don't want to sacrifice a ton to save 500 bucks esp if those heads come with springs that will work already on them. I want to take them out of the box and bolt them on. Thanks to all, without this forum and you guys id be totally lost with the LS stuff
