Need a new cam any suggestions
Compression ratio
Rear gears/tire size (height)
Vehicle/weight
Clutch/Converter stall size
Intended usage of vehicle..Auto X/Drag/Street w/ocassional track ?????
Induction setup....LS6/Fast/Carb(1or2plane)/ITB
OP, can you supply a bit more information mainly what A.R. Shale Targa has asked?
I have something in mind, but I'd like to see what other modifications you have done before I make that suggestion.
Compression ratio
Vehicle/weight
Compression- 11:1
Stock rear; 315/45r18
Full interior 2000 Trans am
Monster stage 3 clutch tick master
Weekend driver with some track time autox and strip
Fast 102/102
42lb Mustang injectors
This is more than enough overlap to have a healthy idle.
I just looked the specs up for that cam and I see it is a good bit larger than what I recommended. If you would like something in between what you have now, and what I recommended at first a 243/246 .624/.595 113+3 would be a good recommendation.
That said...
LSA is not the determining factor in how a camshaft will idle. LSA or lobe separation angle is a mathematically derived equation of two known center lines. Intake and exhaust.
The intake center line(or ICL) is the highest point on the intake lobe and the exhaust center line(ECL) is the highest point on the exhaust lobe.
If we have a 112ICL and a 116ECL then this means that there are 228 crank degrees of revolution in between the intake and exhaust maximum lobe lifts.
Since the cam rotates once for every two crank revolutions, to determine how many cam degrees these lobes are separated apart from one another we divide 228 by 2 which = 114. This is how LSA is computed.
All it tells us is how far the two lobes max lift points are separated from one another. If we bring those center lines in tighter we create more overlap of the opening and closing ramps of the intake and exhaust lobes. If we widen them further apart we create less overlap between those lobes. If we leave the center lines alone and add intake or exhaust duration we also increase overlap.
Overlap is what gives you the sound at idle everyone loves.
That said...
The best bit of advice I can give is to find some cams you like the sound of in the size engine you have. Find their cam specs and compute the amount of overlap they have. This will give you a general idea of what different amounts of overlap in your size engine will sound like.
As Colorado Speed hinted at as well, you can even have a cam with the same @.050 durations and same ICL and ECL, but have differing durations @.006 and they will also sound different.
Confusing enough yet?
If we kept the duration@.050 239/246 and made it a 112+2 or a 111+2 the valve events would be different than they would be at 239/246 114+2.
When I spec a cam I choose a set of valve events that I feel will work best. These coincide directly with the intake/exhaust durations and center lines that will be ground to achieve those events.
The 239/246 @.050 duration is "similar" to the Polluter with its 239/244@.050 duration, but it's valve events on a 114+2 versus a 111+2 are different and thus will perform different.
I aim for a 112 and up lsa if itll work because it will tend to be less peaky and have more torque and more usable power than any cut tighter. I actually prefer 113 and up but really 1* of lsa (depending on ground in advance) wont matter too much.
I really think you would like the 243/246 .624/.595 113+3 I recommended if you wanted something that will make strong low end as well as top end.
