Loss of HP
Old Mar 11, 2003 | 03:10 PM
CamM's Avatar
Default Loss of HP
I bought my 6.0L heads from a local head porter in Houston. I took the heads back off to investigate why I wasn't making the HP numbers like I should. Found out the valves weren't seating properly and I could see light through the bottom of the valves. Anyway, I was basically told by him this is normal for a street/strip head and that valves seal better when hot. I don't want to flame this guy, just wanted to hear un-biased opinions. Any thoughts?
Old Mar 11, 2003 | 03:28 PM
a1s2d3f4's Avatar
Default Re: Loss of HP
The way to check that is with a leak down test. If you get 0 to 2 hot(If you check it cold it will be about 3 to 5) it will be ok. If you get more you might need to get it check out.
Old Mar 11, 2003 | 03:49 PM
L4m3r's Avatar
why would this be any different from stock heads? I have never seen light from them <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> can you explain that?
Old Mar 11, 2003 | 04:02 PM
CamM's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by a1s2d3f4:
<strong> The way to check that is with a leak down test. If you get 0 to 2 hot(If you check it cold it will be about 3 to 5) it will be ok. If you get more you might need to get it check out. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Also, the valves are not seating flush in the combustion chamber and I was already told I need a valve job by a third party. It just doesn't seem normal. They are 2.02/1.57 Ferrera valves..btw
Old Mar 11, 2003 | 04:22 PM
TEA Brent's Avatar
Those are the valves that I use and they seal perfect when cold and hot. I assure you if done right those valves will not have any light. The valve job must be really out of shape. I vaccum check every chamber upon completion, I think it should be a manditory step for everyone to use otherwise stuff like your situation happens.
Old Mar 11, 2003 | 05:11 PM
a1s2d3f4's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by TEA Brent:
<strong> Those are the valves that I use and they seal perfect when cold and hot. I assure you if done right those valves will not have any light. The valve job must be really out of shape. I vaccum check every chamber upon completion, I think it should be a manditory step for everyone to use otherwise stuff like your situation happens. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">This set of heads has been run already
<small>[ March 11, 2003, 05:16 PM: Message edited by: a1s2d3f4 ]</small>
Old Mar 11, 2003 | 05:26 PM
L4m3r's Avatar
funny i had a set that were never run and he told me this problem would go away after they were run.... <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Mar 11, 2003 | 05:32 PM
L4m3r's Avatar
correct me if im wrong... but if your using 2.02/1.57 valves wouldnt that be the stock seat? and if that is true... shouldnt every set of s <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> tock "run" heads have this same problem????
Old Mar 11, 2003 | 05:39 PM
a1s2d3f4's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by L4m3r:
<strong> correct me if im wrong... but if your using 2.02/1.57 valves wouldnt that be the stock seat? and if that is true... shouldnt every set of s <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> tock "run" heads have this same problem???? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes you are correct, they should use the same seats. But with aother valve job.
Old Mar 11, 2003 | 05:40 PM
JPR's Avatar
JPR
Anyone here should never see light between the seat and valve ever in any head performance or stock. there is a specific seat to valve contact area, if that has been established and your still seeing light then you have either bent valves or a cockeyed seat.
Joe.
<small>[ March 11, 2003, 05:42 PM: Message edited by: JPR ]</small>
Old Mar 11, 2003 | 06:52 PM
JS12's Avatar
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by L4m3r:
<strong> correct me if im wrong... but if your using 2.02/1.57 valves wouldnt that be the stock seat? and if that is true... shouldnt every set of s <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> tock "run" heads have this same problem???? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes you are correct, they should use the same seats. But with aother valve job. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">can you explain this "valve job" <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
i was told that you would have to cut down the seat to fit the 1.57 valve....
Old Mar 11, 2003 | 08:13 PM
JordonMusser's Avatar
you should not see ANY LIGHT, period. you need to do a fresh valve job on them.. and check to make sure the valves arent bent
Old Mar 11, 2003 | 09:10 PM
DaleMX's Avatar
Upon having a ASA valve job done on my heads, I had to shim the rockers up .030 just to get mine to close. Hope this helps. (assuming that the head is on the car still).
Old Mar 11, 2003 | 10:25 PM
Texas Terminator's Avatar
THROW THE HEADS THROUGH HIS FRONT WINDOW!!
JUST KIDDING!! EXCELLENT VALVES, CRAPPY JOB. SOMETHING IS DEFINATELY WRONG. YOU SHOULD NEVER SEE ANY LIGHT THROUGH THE VALVES, HOT OR COLD.
Old Mar 11, 2003 | 10:26 PM
Old Mar 11, 2003 | 11:58 PM
Louis's Avatar
Cameron, What are your plans now? feel free to PM or email me. Ill be in town saturday, for an entire week, you should stop by <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Mar 12, 2003 | 07:08 AM
CamM's Avatar
Thanks for the responses. Apparently this head porter thinks all of us are wrong and he is right. I now know of 3 heads from this porter that have had the same problem. Buyer beware.
Sent you a PM, Louis.
Old Mar 12, 2003 | 08:26 AM
BigTex's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by CamM:
<strong> ...I now know of 3 heads from this porter that have had the same problem. Buyer beware.
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Might be helpful to know who ported your heads. Send me a PM if you don't want to post it. Thanks
Old Mar 12, 2003 | 10:23 AM
FreakZ's Avatar
<strong> Anyway, I was basically told by him this is normal for a street/strip head and that valves seal better when hot. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That does not sound like something he would say?
Old Mar 12, 2003 | 10:33 AM
L4m3r's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Silver99LS1:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by CamM:
<strong> Anyway, I was basically told by him this is normal for a street/strip head and that valves seal better when hot. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That does not sound like something he would say? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif"><img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
