valves open on base circle?
Ps, how should this engine run na for a while untill the winter turbos? Th400, turbo converter (3500), 3.25 gear, 3500 lb through manifolds. Hoping at least 12s.
Back on topic. Help!
Thanks!
Straight out of the repair manual:
1. Rotate the crankshaft until number one piston is at top dead center of compression stroke. In this position, cylinder number one rocker arms will be off lobe lift, and the crankshaft sprocket key will be at the 1:30 position. If viewing from the rear of the engine, the additional crankshaft pilot hole, non-threaded, will be in the 10:30 position. The engine firing order is 1, 8, 7, 2, 6, 5, 4, 3. Cylinders 1, 3, 5 and 7 are left bank. Cylinders 2, 4, 6, and 8 are right bank.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
2. With the engine in the number one firing position, tighten the following valve rocker arm bolts: Tighten
Tighten exhaust valve rocker arm bolts 1, 2, 7, and 8 to 30 N·m (22 lb ft).
Tighten intake valve rocker arm bolts 1, 3, 4, and 5 to 30 N·m (22 lb ft).
Rotate the crankshaft 360 degrees.
3. Tighten the following valve rocker arm bolts: Tighten
Tighten exhaust valve rocker arm bolts 3, 4, 5, and 6 to 30 N·m (22 lb ft).
Tighten intake valve rocker arm bolts 2, 6, 7, and 8 to 30 N·m (22 lb ft).
Doesnt make sense? Why not? Correct me if I'm wrong, crank rotates twice the speed the cam does (2:1 crank being the 2). With the valve fully extended into the cylinder, one full rotation of the crank would equal 1/2 rotation of the cam, yes? So one half rotation from full open should be fully closed (from lobe to base circle?) May be misusing my terminology. I know its not as efficient as the TDC method, but I can't believe it to be less accurate.
7.4 pushrod.
Again, in no way are the bolts near 22ftlb.
I'm looking down the exhaust ports with a light. Visible seperation. At least there was....
Now they all appear to be fully closed. Could the lifters have been 'pumped up'? Again may be some terminology issues.
