OEM Cam Chart by SN and lift dur specs
So bang for the buck, what is the best OEM cam still available to reach the magic 400HP mark on an otherwise stock LS1? I see several cams were available, LS9 or even the illusive ZR1 cam?
Is there a chart with PN and cam specs available? Especially one with expected outputs with specific injectors.
Also I see the Yellow Flex Fuel Injectors have a greater output rating, anyone running these?
