Cam problems please help
Old Apr 17, 2014 | 02:05 PM
Horsepwraddict's Avatar
Originally Posted by 64post
You say the fault won't clear and returns immediately? (hard fault) That sounds like an open or shorted wire between ecm and sensor. Use a DVM with audible function, disconnect sensor and disconnect ecm and see if there is continuity to ground at any of the power (12v) or reference (5v) pin connectors then check them connector to connector to see if any of the 3 are open.
This.
play with the plug too. Lots of times wires are broken right at the plug and they get overlooked. Pull on them and see if any stretch. Also check the pins/terminals in the plug/sensor. If they have been on and off a bunch of times they can become loose and not make good contact. DONT PROBE THE TERMINALS WITH ANYTHING WHILE TESTING, just put the tester on the end. That will only spread them out and make another problem.
Old Apr 17, 2014 | 02:48 PM
Darkman's Avatar
See attached.
File Type: pdf
Old Apr 17, 2014 | 06:22 PM
carhy11280's Avatar
ok here is an update. pins were messed on plug so i put a new pigtail on. my cam sound is back sounds mean as hell but im still popping and my o2 sensors are too far apart and still have the p0343 code. i have no idea what is going on but i am stumped i cant tune this car with this code on.
i checked continuity from ecm to pig tail plug by the old egr valve all good. check from pigtail to sensor plug and all good. plug pigtail in by egr and tested from ecm to sensor plug and no resistance at all. My car now sounds like an ms4 should but my o2 are bank 115mv bank 2 424mv at idle. im guessing that it is still off because of the code.
Any ideas?
Old Apr 17, 2014 | 06:28 PM
carhy11280's Avatar
I have not tested continuity to ground from the trigger or feed i will do this.
but why is my car lopping now like it should?
Old Apr 17, 2014 | 06:29 PM
Darkman's Avatar
The P0343 code will not clear itself - did you clear it with a scan tool?
Old Apr 17, 2014 | 06:31 PM
carhy11280's Avatar
all i have is hp tuner and i dont know how to clear a hard fault unless all i have to do is hit the x next to scan.
Old Apr 17, 2014 | 06:34 PM
Darkman's Avatar
It will clear itself from the PCM after one successful test, but will show up on the check engine light for 3 successful ignition cycles. Another way is to disconnect the battery for 30 minutes.
Old Apr 17, 2014 | 06:40 PM
carhy11280's Avatar
ok battery is disconnected ill try that first.
Old Apr 17, 2014 | 06:44 PM
LS1MCSS's Avatar
You don't have the cam and map sensors plugged into the wrong place do you?
Old Apr 17, 2014 | 08:21 PM
carhy11280's Avatar
I have map reading on hp tuner so i doubt that and wire colors are pink and black , brown and white and a red feed line.
Old Apr 18, 2014 | 04:41 PM
carhy11280's Avatar
ok this code will not go away wtf im ready to run this thing off a cliff
Old Apr 21, 2014 | 09:52 PM
  #32
carhy11280's Avatar
Ok guys figured it out the cam in the car was for ls2 and didnt have reluctor ring at all lol. Thanks for your help got another cm from texas speed this time not from someone else.
