LQ4 build going in rolling 2000 SS Camaro
#41
"set rocker to zero valve lash (my understanding of zero valve lash is when the rocker cannot move vertically off of the rocker pedestal, but the rocker arm may move side to side (horizontal) from the valve spring steam/valve spring side) - IS THIS CORRECT? - Yes I've searched the forms and I find some definitions, but they're lacking in specifics -using vague terms like the wiggle method..... wiggle in what directions!?!?!"
Yes you are correct on zero lash. Once you take all the up and down slack out of the rocker that is zero lash.
