cam or turbo
Old Apr 16, 2014 | 10:07 AM
White6SpdZ28's Avatar
Default cam or turbo
Have a 99 z28 full bolt on and can't decide which way to go. I still have the stock ls1 and trying to decide if I should go cam or turbo. My eventual plan is to get a lq4 or lq9 and build it but that will take time. I want to do something performance wise now. I'm posting from my phone so I'm not sure if my mods will show in a sig or not. Just trying to get some insight
Old Apr 16, 2014 | 10:56 AM
WS6ICK2k's Avatar
Your stock bottom end won't last long going over more than 8+ lbs of boost. You could do a cheap non ported set of ls6 heads milled along with a cam and get around 420-430 to the wheels or so.
Old Apr 16, 2014 | 11:13 AM
Well I'm getting my hands on some 799 heads for free and was going to get them cleaned up and everything. Was looking at the ms4 cam or the torque v2 cam.
Old Apr 16, 2014 | 11:52 AM
Blackpanther99's Avatar
Cam... Torquer V2 will do good. You can port and mill the heads. Or try getting some 243s.
Old Apr 16, 2014 | 12:24 PM
I thought 799 and 243 heads were basically the same
Old Apr 16, 2014 | 12:30 PM
Rise of the Phoenix's Avatar
They are. AI, TEA, Texas Speed, Livernois, Flowtech Inductions, WCCH all have CNC programs for 243/799 heads.
How much is your budget and how much power are you looking to make? What other supporting mods do you have?
Old Apr 16, 2014 | 01:21 PM
Ls6 intake. Ported tb. Pacesetter long tubes Ory slp lm2. 9 in with 4.10 gears tunnel mount torque arm. Spohn lower control arms. Feel like I'm missing stuff. Looking to stay around $2500. Ill be jnstalling the cam myself and then getting it tuned. Would like to have 400 at the wheels.
Old Apr 16, 2014 | 01:55 PM
MikeWS6's Avatar
Some cam only cars get lucky and go over 400. My car needed a set of heads as well because the stock 1998 806's are weak.
Old Apr 16, 2014 | 02:51 PM
400 at the wheels can be done cam only pretty easily. No need to go turbo to do that. Now, if you're going to want more, then going turbo might be the smart thing to do.
Old Apr 16, 2014 | 04:23 PM
ls1 1990 VN's Avatar
Turbo you will have better drivability & same sort of power with low boost as a med/big cam
Old Apr 16, 2014 | 05:34 PM
1bdbrd's Avatar
8lbs from what? And where does that number come from? There are many in the forced induction section dispelling that rumor as we speak.
Old Apr 16, 2014 | 06:06 PM
It's not a dd so not too concerned about drivability
Old Apr 16, 2014 | 06:16 PM
JoeNova's Avatar
Restricted User
Boost does not equal horsepower, so your statement is invalid.
There are dozens of guys in the forced induction section pushing 15-20+ pounds of boost at anywhere from 600 to 900 horsepower to the wheels on a stock LS1 with a cam. Some of them have been at that power level for a couple of years now.
Old Apr 16, 2014 | 07:29 PM
And looking at cams I was planning on ordering cam kit with springs and pushrods. Also ls7 lifters. Oil pump. Timing chain. Trunion upgrade. I'm at about 130k. Anything else I should get? Or need
Old Apr 16, 2014 | 07:37 PM
Burken01's Avatar
Ls2 lifter trays...
Yeah if your budget is $2,500 stay away from turbos lol
Old Apr 16, 2014 | 08:04 PM
Well I know it's not the greatest route. But if I went turbo I could do an eBay kit. Put it on and replace the turbo later with a better one. Not the greatest way to do it I know. Just want more power
Old Apr 16, 2014 | 11:13 PM
Burken01's Avatar
$2,500 still won't cut it..
Also a good turbo tune is expensive lol at least 500-1k is an average range..
There's so many little things that add up that you would never think of, oh and the fabbing, labor, time to finish it etc...
A turbo car is a diffrent animal compared to a cam build
Old Apr 16, 2014 | 11:40 PM
No I get that. Cam it is then. Now just which one
Old Apr 17, 2014 | 02:38 AM
List what your car has got now! clutch! diff ratio! engine bolt ons! etc & watch as your $2500 dissapears very quickly. GL
Old Apr 17, 2014 | 06:58 AM
Posted earlier. Clutch was a stock replacement. Know it won't last long so that will be the next thing after a cam. Few months and I'll replace it again. Have a 9 in with 4.10s now
